20 Most Recent Saeco Odea Go Questions & Answers
There are different possibilities for your problem. First the motor might be damaged and is more weak than before that is why is stop when it need to grind beans. In this case only with replacement motor can solve the problem.
Second probably due to long use of oily coffee or low quality coffee beans or other reason there are coffee grounded in the grinder that become like rubber and does not leave the new coffee to pass through grinding burrs. For this either you have to dismantle the whole grinder and its burrs and clean them with brush or you can use a new magic product that you can fin in eBay it can clean automatically the grinder in 30 second see it at the link
http://www.ebay.com/itm/PULY-GRIND-COFFEE-GRINDER-CLEANER-CRYSTALS-20-GRAMS-PACK-OF-3-PACKETS-/131031511160?ssPageName=STRK:MESE:IT
You can try the above fist and you may solve the problem in minutes if not then you can proceed with the replacement of the ginder burrs or motor.
Saeco Odea Go | Answered on Mar 13, 2018
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Saeco Odea Go | Answered on Mar 03, 2018
when the red light blinking it means machine must be primed. BUT if you prime it and still red light -you have to change the FLOWMETER.
Saeco Odea Go | Answered on Jan 14, 2018
hi,
when the machine is On for long time ,it going in the STAND BY MODE-green light is flashing slowly.Just press coffe button and wait for a 10 seconds.
When the red light is ON and no flashing it is mean there is no water in the water tank or too much water in the drip tray.
There are multiple models that are listed as Odea Go series. Unfortunately the espresso community does not speak highly of these machines because of the low quality parts and assembly processes. The manufacturer for this unit has changed several times.
Saeco Odea Go | Answered on Nov 04, 2017
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
Saeco Odea Go | Answered on May 21, 2017
Did you try to put grease on the brew unit to make it movement easy?
Saeco Odea Go | Answered on Apr 30, 2017
Change the heater
Saeco Odea Go | Answered on Mar 26, 2017
Try this remove the brew unit and clean the screen, the red light is saying that it cannot push water through.
Saeco Odea Go | Answered on Dec 15, 2016
the red light for descaling you can turn off when press and hold the steam/hot water button for 5-6 seconds.
Saeco Odea Go | Answered on Jun 02, 2015
During water pump test the led flashing with the speed of the turbine rotate.Tell us if during the test if water running (I think that there is no damage from the ''mistake'' you made). Take a look at the tubes of the turbine and make sure that you have put correct input - output.
Saeco Odea Go | Answered on Apr 27, 2015
Saeco Odea Go Logo
241 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
ODEA Saeco
  • ODEA Saeco
Most Popular Question
saeco odea go coffee machine grinder
  • Coffee Makers & Espresso Machines
