20 Most Recent
ASUS Google Nexus 7 Questions & Answers
How can I download flash player ?
Tap "Install" on the next screen to confirm. When Flash is installed, head into your phone's stock browser (again, Google Chrome won't support your newly-installed Flash apk). On Android 3.0 or later, go to Menu (three dots next to the address bar on some phones) > Settings > Advanced > Enable plug-ins.
How do I get past the wifi question page
hai, do the first time user must activate the wifi to recognize, update a lot their systems and create your profile, not by the network wee usually use. so go find hot spot or borrow some one wifi connection for.
After the process done, you can use network connection and data traffic like usual.
hope its help
It won't turn on
Let's try to hard reset your device, not sure if this will work on both models (2012 and 2013). What you are going to read next is a C/P, best of luck.
Hard Reset or Wipe via Menu
If your device is completely unresponsive, you still have one additional option.
1. Press the power button and both volume keys for several seconds. The computer screen will eventually blink off. Continue to hold until you see the Android recovery logo and the large Start selection at the top of the screen.
If you are forced or desire to factory reset and wipe the device, select Recovery Mode. Your device will reboot. This reboot will be much slower than normal.
2. When you see the Android with red triangle, hold the power button down and press the volume up key until the wipe data/factory reset option appears. Press the power button to select it. Remember that this will erase all the data on your device.
3. With the volume keys select Yes - erase all user data and again press the power button to select this option.
Cant get any apps
Hi Kim,
Inconvenience regretted, it may happen when the Framework services are blocking the Market. Here is what you need to do:
1. Click on Menu button> Settings
2. Select Apps
3. On Top right hand side, you will see "Downloaded", scroll left to see "ALL"
4. Under "ALL" , select "Google Services Framework" and click "Clear Data".
Now try to access "Play Store" and download Apps.
Thanks!
I can not connent my nexus 7 to inter net
If you're still carrying this problem with you and haven't found an answer to this. You can always set your device back to factory settings and start all over.
Notice: You should back-up your data first!
Google support
Is this after serveral power-off and power-on attempts?
If so, you may need to reset it to factory defaults by entering "recovery mode".
Google "nexus 7 recovery mode" and follow the options within. All data on your nexus 7 will be lost.
Problems to download movies using Netflix
What sort of problems are you having? Connecting to the internet? Are you receiving any error messages? In order to troubleshoot your situation, we would need to gather more specifics to assist.
