20 Most Recent
Jenn-Air 24 in. JDB1250 Built-in Dishwasher Questions & Answers
Start button does not light
please follow this steps and fix it. GOD BLESS YOU1.
No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power. Sometimes the power cord disconnects at the dishwasher (inside
the junction box, behind the bottom kick panel), if this is the case,
the wiring must be repaired or replaced.
2.
Door switch
Replace if defective.
3.
Timer or Electronic control
Replace if defective (note: uncommon problem).
4.
Selector switch
Read more:
http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00
The soap dispenser at times does not open during
Check the way you're loading your dishwasher. Sometimes large plates or baking pans can block the door of the dispenser. The latch unlocks but because the door is blocked, the detergent can't get out. Once you open the main door, the dispenser door may pop open and looks as if it has been in the fully opened position when it was actually held in place by that large utensil!Cutting boards are major blockers as well.
I hope this helps. If it does, please come back to fixya and rate my answer
Dishwasher not rinsing or cleaning properly. It
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Installed a Jenn Air 1255A
the machine has a 2 ( moment) fill time this may be 60 sec each the if the float is floating and the water shuts of at 1 or 1and 1/2 min there will be a 30 sec delay . but it should get going after this . if it will not go after the fill eith its the wash motor or the main control . as it controls the time . even though new it could be a bad control .. mm
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
WATER LEAKS UNDER THE SINK WHEN DISHWASHER IS IN
Check the connection to the drain tailpiece from the dishwasher under the sink and make sure the clamp hasn't slipped off and is tight. Check the drain hose from the dishwasher and be sure it's not split or damaged. Check the drain spur on the drain tailpiece and see if it's corroded or leaking. Check the trap under the sink as well and make sure it's not leaking.
10/17/2017 8:44:12 PM •
Jenn-Air...
Answered
on Oct 17, 2017
