20 Most Recent Frigidare FGB24S5DC Gas Single Oven Questions & Answers
Oven model FGF316ASA OVEN WILL NOT IGNITE
change the igniter its just weak cost around $65 for universal fit takes 15min to change
11/20/2013 2:25:26 PM • Frigidare... • Answered on Nov 20, 2013
Dishwasher not cleaning the dishes
have you cleaned the fliter in the bottom
11/20/2013 2:23:37 PM • Frigidare... • Answered on Nov 20, 2013
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge unless you put something heavy on door , this should work
11/20/2013 2:22:55 PM • Frigidare... • Answered on Nov 20, 2013
I have Fridgidaire 30
your model says its a 24" but the hot surface igniter for oven is bad it should have a seperate one for broiler check here on fix ya ( hot surface igniter)
11/20/2013 2:20:32 PM • Frigidare... • Answered on Nov 20, 2013
The ignition coil on my oven glows fine, seems
it may glow but it s weak the gas wont flow seems like alot of these going bad I had 3 last week in my rentals
11/20/2013 2:14:40 PM • Frigidare... • Answered on Nov 20, 2013
My oven is not lighting like it is getting no gas.
your igniter is weak if you turn on gas to light and it takes awhile , or not at all, weak igniter in most cases
11/20/2013 2:12:21 PM • Frigidare... • Answered on Nov 20, 2013
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
11/20/2013 2:09:03 PM • Frigidare... • Answered on Nov 20, 2013
Propane oven will not get up to tempature
change the igniter had the same problem I was told the oven cools off because igniter isnt allowing gas to flow it will lite but temp isnt there
11/20/2013 2:07:58 PM • Frigidare... • Answered on Nov 20, 2013
Self cleaning lock not disagaging
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
9/30/2010 4:01:15 AM • Frigidare... • Answered on Sep 30, 2010
Oven comes on- but will not get hot
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
4/26/2010 2:49:23 AM • Frigidare... • Answered on Apr 26, 2010
2answers
Electronic ignition works, but the gas does not come on
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
6/26/2009 12:21:59 AM • Frigidare... • Answered on Jun 26, 2009
Gas oven not heating
Hi, the oven temp sensor is not registering correct temp signals. i recommend replacing the oven temp sensor asap.
6/19/2009 7:49:54 AM • Frigidare... • Answered on Jun 19, 2009
How long do I leave my GE oven in the
You would be a fool to even use the self clean mode. The 900 degree temp plays hell with todays expensive Mexitronics. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6/12/2009 2:49:17 AM • Frigidare... • Answered on Jun 12, 2009
Need directions for self cleaning oven
Hi Debi
Unfortunately I was unable to find the manual in my database. But still found the solution you can click on these links and refer to the instructions :
How to self clean Gas Single Oven
Directions for cleaning Fridgidaire
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks Rylee
4/8/2009 1:42:25 AM • Frigidare... • Answered on Apr 08, 2009
Need to adjust Oven door to shut tight
adjust on screws on door hinge
2/17/2009 10:21:00 PM • Frigidare... • Answered on Feb 17, 2009
Adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
11/9/2008 11:22:20 AM • Frigidare... • Answered on Nov 09, 2008
F10 code flashing on my frigidare oven
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electricrange cavity and relay it to the oven's main control so it knows when to shut off the heating elements. Hope this helps Bob
9/22/2018 4:04:09 AM • Frigidare Ovens • Answered on Sep 22, 2018
Frigidare FGB24S5DC Gas Single Oven Logo
Popular Tags
42 questions posted
Top Frigidare Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidare Ovens
  • Frigidare Ovens
Most Popular Question
electronic ignition works but gas not
  • Ovens
