20 Most Recent Samsung Galaxy S 3 III / S3 / i747 i-747 / L710 L-710 White Toad Frog Peeking Pets Design Silicone Skin Soft Gel Snap-On Protective Cover Case Cell Phone Questions & Answers
I forgot my passcode to access my phone?
Sorry we have no way to know your personnel passcode.
2/13/2018 11:13:00 PM • Samsung Galaxy S... • Answered on Feb 13, 2018
Want to tranfer live wall paper from samsung s3 to pc
Try using the blu tooth option. If your PC doesn't have a blu tooth adapter then Walmart or best buy have them.
12/31/2014 12:39:25 AM • Samsung Galaxy S... • Answered on Dec 31, 2014
I forgotten my pin on my samsung s3 and I don't now what to do can u help me plz
Factory reset from recovery is d vest method but u can try methods given in d link.....some require root some do not...
5/8/2014 5:32:27 PM • Samsung Galaxy S... • Answered on May 08, 2014
0answers
I dropped my cellphone and it cracked badly and the screen is black, what is my best option?
If you age the skills you could try, but there are lots of phone repair shops, that will do the job for not much more than the screen costs. If in the end you can't make the pone work, you will have to consult a repair shop anyway and you almost have to pay twice, because they never try to finish jobs that went wrong.
12/2/2013 9:41:17 PM • Samsung Galaxy S... • Answered on Dec 02, 2013
SIM NETWORK LOCKED FROM AT&T
Very easy, don't even need IMEI:Go to the phone and enter into the dial pad:*#197328640#[A menu should pop up, select UMTS> Debug Screen> Phone Control> Network Lock> PERSO SHA256 OFFAt this point you will be waiting at a screen that says SHA256_OFF= Not Change. Wait for thirty seconds and hit the menu button (To the left of the home button) and select back. Wait an additional minute and reboot your phone, it should be permanently unlocked
1/26/2013 9:53:22 AM • Samsung Galaxy S... • Answered on Jan 26, 2013
0answers
0answers
Need manual
Be the first to answer 11/6/2013 11:06:07 PM • Samsung... • Posted on Nov 06, 2013Be the first to answer
Protection appears across screen and wont let me
The media you are using has the recording protection on.
12/15/2009 6:33:19 PM • Samsung... • Answered on Dec 15, 2009
Samsung Maxima 105 zoom
I have the manual. I'll scan it for you & email it. My problem is that the manual doesn't identify the batteries & I lost the ones I'd removed for storage.
2/24/2009 6:16:32 AM • Samsung... • Answered on Feb 24, 2009
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
I lost one of the little rubber ball-like feet off my tripod 1612201. Do you have them available?
We don't have anything available Elizabeth. We are Fixya, and we only supply free information. It would be useful to know the maker as the '1612201' doesn't bring much up and looks like a serial number. Your local camera shop can get them, or you can get online. https://www.google.com/search?q=tripod+feet+replacement //
2/9/2024 6:10:43 AM • Photography • Answered on Feb 09, 2024
Samsung Galaxy S 3 III / S3 / i747 i-747 / L710 L-710 White Toad Frog Peeking Pets Design Silicone Skin Soft Gel Snap-On Protective Cover Case Cell Phone Logo
23 questions posted
Top Samsung Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Photography Expert? Answer questions, earn points and help others
View Most Popular
Samsung Photography
  • Samsung Photography
Most Popular Question
forgot passcode access phone
  • Photography
