20 Most Recent
Tannoy Reveal 5A Speaker Questions & Answers
Getting very low volumn only and lots of crackling if turned up
As long as it is only the speaker that is playing up and not the amp. Then more that likely it will be something on the crossover circuit that is the problem. If you look at that and see semi-conductors (transistors, IC, etc) on it. Then one or more of them could be the problem.
My Tannoy Reveal 5A Powered
Hi,low hum from monitor speakers are usually when there is not shield connected to the cables your using for connections. Also it might be from the power light,if there is no earth or ground connected before connecting the power source in that room.
So you will need to check the cabling properly and check how the (sleeve, tip and ring) are connected and also check the power outlet,if the (red,black and yellow or white) are connected properly.
after checking those if they are OK,that means the fault will be from the speaker itself.\
Just do a proper troubleshooting.
Thanks for using fixya.....
My Tannoy Active monitors are connected to a
Check the gain structure through the board.
Check all the mix bus assignmentsie what is routed to the masters.
Normally hiss can be reduced with good gain structure and ensuring all not being used is correctly turned off.
Test the speakers with another suitable source
If the speaker are less hissy on the alt source and you have checked all the mixer gains and eq, it is possible the board is noisy because of some component failure. Try audio isolation transformers on the output of the board, beg or borrow a good quality pair first to test, as they are expensive.
Thanks for using FixYa, I hope this if its useful
