20 Most Recent Nikon Used N75 35mm SLR Autofocus Camera Kit with 28-80mm Questions & Answers
My Nikon FM has an issue where every-other time I advance the film the shutter mirror flips up and the shutter goes off. I can actually watch the mirror go up as I'm winding if I take the lens off
It sounds like your Nikon FM may be experiencing a mechanical issue with the shutter mechanism. Here are a few troubleshooting steps you can try:
  1. Inspect the Film Advance Mechanism: Check the film advance lever and mechanism to ensure they are functioning properly. Make sure there are no obstructions or debris interfering with the movement of the advance lever.
  2. Check the Shutter Release Button: Inspect the shutter release button to see if it's sticking or malfunctioning. Sometimes, a stuck or sticky shutter release button can cause the shutter to fire unintentionally.
  3. Examine the Mirror Mechanism: Carefully inspect the mirror mechanism to see if there are any visible signs of damage or misalignment. If the mirror is flipping up unexpectedly, there may be an issue with the mechanism that controls its movement.
  4. Clean and Lubricate: If the camera hasn't been serviced in a while, it's possible that dirt, dust, or dried lubricant may be causing the issue. Consider cleaning the internal components of the camera and applying a small amount of appropriate lubricant to the moving parts (be cautious and follow proper procedures when lubricating a camera).
  5. Seek Professional Repair: If the issue persists after attempting basic troubleshooting, it's advisable to have the camera inspected and repaired by a qualified camera technician. They can diagnose the problem more accurately and perform any necessary repairs or adjustments to restore the camera to proper working condition.
  6. Use a Different Lens: Sometimes, issues with the lens can affect the camera's operation. Try using a different lens to see if the problem persists. If the issue only occurs with a specific lens, there may be a problem with that particular lens.
It's essential to handle the camera with care during troubleshooting, especially when accessing internal components. If you're unsure about performing any repairs or adjustments yourself, it's best to seek professional assistance to avoid causing further damage to the camera.
3/16/2024 9:18:35 AM • Nikon... • Answered on Mar 16, 2024
Test question ~ please delete
11/17/2023 4:59:16 AM • Nikon... • Answered on Nov 17, 2023
My Nikon FE film advance lever is stuck. It does
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
4/8/2022 9:42:31 PM • Nikon... • Answered on Apr 08, 2022
How to replace nikon f3 shutter?
There are youtube videos on this type of repair to DSLR cameras and I dont recommend that you try it unless you have incredible talent for small details and a very clean environment.
6/22/2021 1:55:43 AM • Nikon... • Answered on Jun 22, 2021
My Nikon is coming up with “n1” where the numbers are displayed and the film won’t wind so I can’t remove it, what do I do?
On many cameras, a lens error means the lens is not set to is highest f/stop such as f/16 f/22 and the like. The lens must be put in that mode for the camera so that the camera electronics can auto set the f/stop as needed. First thing I would do is look at the f/stop on lens with manual f/stop settings; such as the Nikon 50mm f/1.8D making sure it is set to the highest f/ number (smallest opening). Remove the lens check the dial. Also, is the battery fully charged? If all that is okay then do the following couple of things; 1. Get yourself a film change bag, they look like a black plastic/rubberish T-shirt. Put the camera in there make sure the bottom is fully closed, put your arms through the sleeves, they have elastic keeping light out. Open the camera carefully remove the film canister then using your fingers rewind the film back into the canister. 2. Okay, you do not have access to a film change bag, easy get a thick blanket or two, go in to a closet, close the door, put a towel at the bottom, cover your camera as best as you can then do the same as if you were using a change bag. Important, make sure you are in a completely dark place without ANY LIGHT working its way through to you. Next, being as your are using film, big congratulations for that, purchase a change bag from Adorama, Amazon, B&HPhoto. Every film shooter should have one. Hope the above helps you.
11/2/2019 6:08:32 PM • Nikon... • Answered on Nov 02, 2019
That is likely a job for an experienced repair technician, not for DIY.
7/10/2018 2:40:38 AM • Nikon... • Answered on Jul 10, 2018
Shutter advance on Nikon F6: with the back open, should the shutter curtains operate when activating the shutter?
Does the shutter operate when the back is closed? (In other words, does it expose the film?) If so, don't worry about it. If not, it may need service -- or it may be set at such a high shutter speed (1/2000, for instance) that makes the shutter open and close so quickly that you can't see it move.
10/6/2017 1:52:08 AM • Nikon... • Answered on Oct 06, 2017
I have a 1967 Nikon F. It previously worked. Haven't used in years, stored in closet in camera bag. I now see nothing thru the viewfinder. What's going on? I am not a photographer, never have been.
if it takes a button battery replace it, or check for fungus growth (yes it happens) within the viewfinder.
9/29/2017 2:54:18 PM • Nikon... • Answered on Sep 29, 2017
My flash compensator will not close
7/18/2016 5:31:13 PM • Nikon... • Answered on Jul 18, 2016
Minimum maximum
7/18/2016 5:21:15 PM • Nikon... • Answered on Jul 18, 2016
Battery will not stay charged
7/18/2016 5:10:36 PM • Nikon... • Answered on Jul 18, 2016
Mastering internal flash
7/18/2016 4:52:27 PM • Nikon... • Answered on Jul 18, 2016
Where lstimer
7/18/2016 4:38:03 PM • Nikon... • Answered on Jul 18, 2016
The flash compensator on my d-90 wont close why?
Sounds like the flash head is damaged, Needs to go to a repair shop,
1/16/2015 9:39:14 PM • Nikon... • Answered on Jan 16, 2015
Red brinks after shutter fired nikon 6006
Only red light that blinks on that camera is the self timer, Camera is set on SelfTimer mode, change to S or C mode
1/16/2015 9:21:33 PM • Nikon... • Answered on Jan 16, 2015
tip
Stuck Film Advance in Manual or Auto Wind 35mm Cameras
I've been seeing a great number of posts from people requesting help with a stuck film advance feature on their 35mm film cameras (you remember "film", right?) Normally, there are just a couple of things you can try to fix this issue before you'll need to find a professional to repair your camera - if it's even worth it. On that note, a lot of people still have film cameras for nostalgia purposes but there are still some hold outs that enjoy film. Finding a repair shop for an older camera isn't impossible but they are getting scarcer. Google "FILM CAMERA REPAIR" and see what pops up in your area! MANUAL ADVANCE CAMERAS: There's a complex number of actions that must work properly in order for you to advance the film in your camera using the manual advance lever. Gears, shafts, bearings and springs come into play and like a clock, they need to mesh together or the advance mechanism comes to a screeching halt. Well, you'll be the only one screeching, most likely but you get the point. If any of those parts break or become unaligned, or if some foreign matter like dust or dirt gets into them, the same thing happens. However, there are sometimes a few things you can try that might prevent you from sending in your camera for professional repair. I caution you about opening your camera yourself unless it has no real value to you because the interior of a 35mm SLR camera is pretty complex, even more so that a clock. Chances are you'll do more bad than good. With that said, try these options: Film Jammed - Won't Advance Sometimes the film will jam in the canister, or in rare instances, isn't actually as long as it's supposed to be and can reach the end of the roll before the camera indicates it has. If you suspect this has occurred then push the film release button and try to wind the film back into the canister before opening the camera. If you don't care if the film gets exposed feel free to do this in the light. It's much easier! At times the film may also pull lose from the canister and roll completely on the take-up reel. If this happens you'll need to take the camera into a completely dark room with the light-proof film container, remove the film manually from your camera, roll the film up and put it into the light-proof container, close it tight and then seal it with electrical or duct tape. Also let the lab know this has happened so they don't pop up the container and expose your film thinking it is still in the canister. Advance Lever Stuck If the actual film advance lever is stuck and won't move, about the only option you have is to open the back of the camera and be sure nothing has jammed in the gears or sprockets of the take up reel or film path. If that doesn't fix the problem try pressing the film release button, wind the rewind lever a bit and see if the advance lever engages again. If the lever just flips back and forth with no tension at all then something inside has broken and your chances of repairing it yourself are almost none. Most film cameras are getting on in years and will just naturally begin to break down over time. There may be no option to even fix your camera unless you find a similar model for parts and send that along to the repair shop. Make sure you get the parts camera back as you may need it later! If you like tinkering and the camera isn't one you'd miss if you couldn't fix it, then you could always give it a shot yourself. You can pick up a set of jeweler's screwdrivers and pliers from the web or Radio Shack for under $20 and find old film cameras on EBay or Craigslist at a decent price. Just be sure they don't have the same problem as your current camera does! Grinding Noise When Advancing Film This is most often caused either by a broken part, metal shavings or dirt/debris in the winding mechanism. Again, if you feel comfortable doing it yourself and it's not an expensive collector's model, you can try to repair it yourself. Hunt down a PDF service manual for your camera on the using Google web (a lot of collectors share them) and it should show you how to remove the cover to see the winding mechanism area. Look for debris in the gears and springs and remove it with short blasts of canned air but be sure you hold the camera so any debris falls out and not further into the camera. You can also use Q-tips dipped in alcohol to remove any debris, but don't use water, and let the area dry completely. Once you've done this, you'll need to apply a light lubricant to the area but only if it was lubricated before you cleaned. Use thin white lithium grease or an oil or grease used by clock repair shops and apply it with a toothpick as you don't need much. DON'T USE WD-40! It will do more damage than help. MANUAL ADVANCE CAMERAS WITH MOTORDRIVE ATTACHMENTS: These are manual wind cameras like the Minolta X-700 or Nikon FM2 that have an attachable motor drive that winds the film for you. Pretty much the same suggestions previously noted can be tried with a couple of exceptions: Check the batteries and contacts in the winder making sure they're clean and not bent or broken. You can clean battery contacts with a CLEAN pencil eraser or alcohol and a Q-tip. Blow any dust and debris out of the compartment afterwards.If you still experience problems remove the winder and be sure the coupling that locks into the bottom of the camera to wind the film is not jammed or damaged. With batteries in the winder and the power turned on, look for a series of contacts on the top of the winder that mate with your camera. Be sure these aren't dirty or broken as well. Using a paper clip, you should be able to short one or more of them to another to activate the winder to make sure it works properly. When All Else Fails - A Bigger Hammer If none of the previous suggestions work and if, ONLY if you don't value the camera for collector's value a firm tap might work as a last ditch effort. I once had an old Minolta SRT that locked up solid. I didn't want to bother with trying to open it up as I only used it for a shelf display so I took the lens off, used a wad of very clean, soft foam to hold the mirror steady and wacked it twice on the counter. Not enough to damage the camera body (or the counter!) but a good smack. Whatever was jammed came loose and the advanced began to work. As I said, I only use it for display so I don't know if it affected the shutter speeds, etc. but it worked and cost me nothing but time. AUTO/POWER ADVANCE CAMERAS: Newer "old" 35mm film cameras used a power winder motor to advance the film and **** the shutter. If you experience a jammed advance on these cameras, check the film path, sprockets and make sure they are clear and move freely, as I described previously. Try the film release button and see if that will release the drive as well. Another option that has worked at times is to remove the film, lens and all batteries from the camera (including any date/time battery) for at least a day or two to see if the camera will reset itself. This worked for me once with a Nikon N70. As a last ditch effort, the table smack might work as well, but I make no promises and it's all your fault if you damage the camera beyond repair... or your furniture!
on Jan 06, 2015 • Photography
Is there a site where someone can download a manual for a nikon ne-20h survey equipment
button_3_i.gif This is the sight that I would go to I used to work on Nikon, Wise and Topcon total stations. I believe the manual that you are looking for would be there if any where. Good luck and have a great day.
11/9/2014 1:45:09 PM • Nikon... • Answered on Nov 09, 2014
Tripod replacement parts
11/8/2014 7:29:42 PM • Nikon... • Answered on Nov 08, 2014
Nikon Used N75 35mm SLR Autofocus Camera Kit with 28-80mm Logo
0 questions posted
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
nikon fe film advance lever stuck
  • Photography
