Battery won't charge, what do I do
More history would help narrow the possibilities, but I'll assume you have had it for a while and have recently found it stopped charging. 3 most common culprits, assuming it will not charge at all: cable, charger, and charging port. If it's the last, buy a new tablet, but not before trying a GOOD quality cable and a charger that is known to work (i.e., it charges something similar). First, look very closely at the charging port, for damage, dirt, dead spiders, missing pieces, etc. If clean and straight, move on to debugging the cable and/or charger. Cheap debugging means borrowing a known good cable and charger from a friend. Not from a stranger. That tends to involve the police and mugshots, and can ruin political aspirations. Replace one thing at a time (cable first), and pay careful attention to getting a good connection. Try every combination, and be patient. If it is the cable, seriously consider getting a higher quality cable. Cheap cables are a huge problem, and can contribute to damaged charging ports. Good luck!
