20 Most Recent
Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator Questions & Answers
My frigidarie refrigerator ice maker does't work
Your inlet tube that goes to the icemaker may be frozen.
To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back.
Use a flexible item to insert in the water line connection.
I used a zip tie. If the flexible item won't all the through
to the ice maker, the line is frozen. Thaw out the tube
from inside the freezer with a hair dryer. Re-connect
everything, you now have ice . . .
Solution #2: You may have to replace your "Water Inlet
Valve" located at bottom right rear of Fridge.
Easy to do, just follow the color codes, be sure and shut
off the water.
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Frigidaire Water Leak
Have you found a solution to your problem? We started having a a similar problem with our Frigidaire.
Thank you.
Ice build up in freezer
Sounds like a defrost problem... need to pull back panel off in freezer and see if u have thick frost build up indicating... heaters, or defrost themostate bad.. could not bring up your model # SO dont know if maybe bad defrost timmer or if you have adaptive defrost control which could also be bad.
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service
https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer
https://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer ยท Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros
https://forum.appliancepartspros.com > posts > t55646...
Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video
https://www.appliancevideo.com > question > refrigera...
Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk
https://hvac-talk.com > vbb > threads > 53155-Frigidai...
Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ...
Domestic Refrigerator Short-Cycling
Dec 4, 2020
Wiring time delay for a short cycling compressor
Jun 23, 2022
Walk-in short cycles
Mar 7, 2021
Walk-in compressor short cycling
Oct 20, 2008
More results from hvac-talk.com
