20 Most Recent
Frigidaire PLRU1777DS Stainless Steel Refrigerator Questions & Answers
Fridge is not cooling at all. I hear the fan running though. Not sure where to start
There may be more than one fan, one or more may be to circulate the cold air through the evaporator (the coils that get cold) and the other is near the compressor or the condenser if the fan beside the compressor is running and the compressor is not, then the most commen problem would be the compressor start mechanism. Something like an RCO410 or a smaller version is the RCO810 the fastest cheapest thing to do is buy one and put it on by following the diagram written on it. If the compressor does not start after that and the condenser fan is still running, you will need a pro to change out the compressor, unless you have experience you can't do that yourself.
My frig is not keeping
Suggest you check the condenser grill in the compressor compartment. If that is dirty or the compressor fan is not operating then your system can not dissapate the heat build up. Which means the unit will not get cold enough even if the compressor is active.
Fridge stays cold but continuously runs
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297005500en.pdf TURN TO PAGE FOUR and check the rtroubleshooting guide. Example gasket control setting etcetra
Not cooling enough, compressor is running well,
AIR FLOW IS THE PROBLEM. THERE IS A DEFROST PROBLEM BLOCKING THE AIR FLOW. OR THE FAN IS NOT WORKING. IF THERE IS FROST ON THE LOWER BACK WALL INSIDE YOU HAVE A DEFROST PROBLEM. REMOVE PANEL AND DEFROST AND CALL FOR SERVICE.
Frigidaire ref not cold
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
