20 Most Recent
ZEEPAD 7 inch Android 2.2 Tablet Questions & Answers
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Why is the screen using 62% of the battery
because it is the most important interface. When you leave the screen off, you also could leave the whole thing off. They still can't make cheap displays that does not use lots of power.
Change the time zone to CST - it is stuck on GMT
Go into your settings, system date & time. Ensure the Automatic date and time is checked, along with Automatic time zone.
You can also make adjustments to time and date formats.
Back out, and restart your tablet to see if this works.
Date\time is a software function. Check to make sure you have the latest software version uploaded.
MY ZEE PAD WILL NOT CHARGE
both of my charging ports are bad , thats your problem also, we need to find a supplier for the parts so they can be fixed..
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
Forgot parren to unlock tablet
You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
