20 Most Recent Nextel BOOST i835g i835 LTD. ED UNLOCKED PHONE i830 Cellular Phone Questions & Answers
Necesito codigo especial para nextel motorola i576
Contact the original service provider for the special code. Mark Motorola Support
9/16/2014 1:19:36 AM • Nextel BOOST... • Answered on Sep 16, 2014
Special code
Mekanda- Contact the phone's original service provider. Mark Motorola Support
9/16/2014 1:16:43 AM • Nextel BOOST... • Answered on Sep 16, 2014
Master reset i576
MasterReset lets Nextel Customer Service reset your service in the event of a security or provisioning problem. Reset Defaults - Reset Settings returns all settings to their original defaults; Reset All returns all settings to their original defaults and erases all stored lists. Use only under the direction of Nextel Customer Service... Mark Motorola Support Motorola i576 User Manual Page 76
9/15/2014 11:26:38 PM • Nextel BOOST... • Answered on Sep 15, 2014
Citycall i930 money
What is your question? Mark Motorola Support
9/15/2014 11:21:32 PM • Nextel BOOST... • Answered on Sep 15, 2014
Codigo especial para titanium de nextel
Contact the Service Provider. Mark Motorola Support
9/1/2014 2:06:51 AM • Nextel BOOST... • Answered on Sep 01, 2014
Unlocking code for i880
You will need contact Nextel to get the subsidy unlock code to use your phone internationally.
2/3/2013 12:33:44 PM • Nextel BOOST... • Answered on Feb 03, 2013
2answers
Boost motorola W385 phone unlock
You can get the unlock code here mobileunlocksolutions.com and also get the unlock instruction in the same site....
11/15/2012 1:33:21 PM • Nextel BOOST... • Answered on Nov 15, 2012
0answers
5answers
Unlock codes for nextel phones
can it be unlocked to work with boost?
7/31/2012 7:03:16 PM • Nextel BOOST... • Answered on Jul 31, 2012
4answers
Unlock code needed
try unlock codes from http://www.unlock-free.com/ and http://www.mobile-unlocker.com/
3/27/2012 1:14:13 AM • Nextel BOOST... • Answered on Mar 27, 2012
3answers
What is the special code to unlock my nextel
12/9/2011 2:24:29 AM • Nextel BOOST... • Answered on Dec 09, 2011
2answers
Wats the code to unlock my boost i835
Get the unlock code here mobileunlocksolutions.com and also get the unlock instruction in the same site..
8/6/2011 4:21:26 AM • Nextel BOOST... • Answered on Aug 06, 2011
2answers
My phone doesn't ring or vibrate also the
Hi,there are three things you need to check..
The vibration..
The ringer...
The flex....
Hi, what makes nothing happens even when trying different levels of the vibration is because the ******** of the phone that makes the phone vibrate when someone calls is damaged.
You need to replace the ******** before it will respond again. It is located inside the phone,always round in nature.
When replacing the ******** of the phone,you have to be careful when unscrewing the phone screws.
Get a phone screw, unscrew necessary screw off, take the back cover off locate the ********, (round like the ringer)But the difference is clear.Go to any phone repair store around your area and purchase another phone by tell them the model and make of the phone.
After replacing the ********, screw back the screws and your done.
Would advice, if no knowledge about phone repairs, please contact a skill full personnel for help.
What causes phones not to ring out is when the ringer that makes you hear a tone when someone calls is damaged and does not work properly again.
The ringer is located inside the phone.You can get access into the phone by unscrewing the phone with a phone screw. It a little bit technical when unscrewing the phone.Just be careful not to damage the phone.
How to unscrew the phone.
Remove the back cover of the phone where the battery is,
then remove also the battery, at the edge you will see where the screw are located.(look closely).
After unscrewing,the screws, Open from the size of the phone,you will see where the ringer is located. It's usually round in nature. Remove and cover up the phone. (you can get a replacement ringer from any phone repair and sale of part store around you.
Ones your through with the ringer , 'wa la' Your done..
Note:if you can't loose the phone, in other not to cause damage to the phone,please contact a skill full personnel for assistance.Thanks.
Before you replace it,you can also clean up the ringer ,there might be dirt stopping it from working properly.
Hope it helped......
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and also the ringer and vibration...
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
8/4/2011 5:59:47 AM • Nextel BOOST... • Answered on Aug 04, 2011
0answers
Hi, this is Marcello from
Welcome to Fixya
This means that the phone is simlocked to a certain provider. If you are going to use a different sim to the phone (Not nextel Sim). The special code will appear and you need to enter the network code for you to be able to use the phone with different sim. You will not be having any problem if you are gonig to use NEXTEL simcard. If you still insist of using different sim there then you need to purchase a code to a thid party site. Click here.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
5/16/2011 5:47:12 PM • Nextel BOOST... • Answered on May 16, 2011
Puk code
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
2/15/2011 11:17:59 PM • Nextel BOOST... • Answered on Feb 15, 2011
How to unlock my nextel phone
Use unlock code to unlock your mobile....Get the unlock code here mobileunlocksolutions.com and also get the unlock instruction in the same site...
12/29/2010 5:49:17 PM • Nextel BOOST... • Answered on Dec 29, 2010
Nextel BOOST i835g i835 LTD. ED UNLOCKED PHONE i830 Cellular Phone Logo
80 questions posted
Top Nextel Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Nextel Cell Phones
  • Nextel Cell Phones
Most Popular Question
unlock nextel phone
  • Cell Phones
