20 Most Recent
Nokia 3310 Cellular Phone Questions & Answers
I have forgotten the security code of nokia 3310
If you forgot the security code you have to reset you mobile............ Its the only way to use your mobile again. After resetting you can enter a new security code again.You can visit here
Unlock-free.com for the master reset code service and get the Nokia reset code........
What is a cellphone IMEI number?
Hey im not sure if this will work.as i have a samsung galaxy s4.
but try it. U never know keep the home button held. And u will c a set of differebt options. That will take u to clearing memory. stop apps that r running in the back and also uninstall if needed to :)
Cell phone dead
check the batteries..charge them and use it..may the battery must be worn out so replace the batteries...or only keypad lights are on and display is off then replace the display..an new display would b around 300 INR.
Android ice cream sandwich signal proble
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
