20 Most Recent Sony Ericsson K310i Cellular Phone Questions & Answers
2answers
Configuration error
take the phone back to the service center and explan what is wrong and tell the person to fix it correctly, just like it should have been the first time.
12/2/2017 10:35:47 PM • Sony Ericsson... • Answered on Dec 02, 2017
2answers
I have sony ericsson k310i handset but it has no lock,any one can use my mobile without my permission,it is irritating.plz help me
yes it does bottom righthand button,pess then press the top left.
1/31/2017 8:53:53 PM • Sony Ericsson... • Answered on Jan 31, 2017
8answers
MY SONY ERICSSON K310I PHONE IS LOCK
It's locked to Network or security lock?You need to unlock it???
It locked to Network means you need to unlock it using the Unlock code,It locked to Security code means you need to use the master reset code and reset it....You can get the master reset code from service provider...........You can get the Network unlock code from here Theunlockspot.com and Unlock it from Network lock,then you can use any GSM Network Sim card...
1/31/2017 8:50:39 PM • Sony Ericsson... • Answered on Jan 31, 2017
2answers
Delete protected files
u need to have ur phone flashed and unlocked to eliminate ur service providers protected files. this can be expensive, and also voids the phones warranty.
1/11/2017 7:11:19 AM • Sony Ericsson... • Answered on Jan 11, 2017
2answers
Protection
hi, not exactly an expert but just a suggestion is to see if you can move the files to an unexpected place but it is hard with sony ericssons because in the multimedia section is shows all files, memory card files and phone memory files so even if yu move em itll show it on all files. otherwise jus rename it to something dat starts wid a letter in the middle of the alphabet so it wont be da first ones or sumfing. sorry if that doesnt work.
10/10/2016 4:32:43 AM • Sony Ericsson... • Answered on Oct 10, 2016
3answers
How to lock the keypad
You can try this, press the asterisk sign (*), and you should see "Lock keys" on the screen. Just hit the designated button where you will see "Lock keys" option.
I hope this one helps.
9/21/2016 9:51:14 AM • Sony Ericsson... • Answered on Sep 21, 2016
It says inactive sim
Could be that the SIM card is locked. Try removing the SIM card and re-installing. First remove the battery, then the SIM, then re-install the SIM and then the battery and turn it back on. Hope this helps.
5/29/2015 7:37:13 PM • Sony Ericsson... • Answered on May 29, 2015
I have a inactive sim how do i fix for a sony k310i mobile
Try settings - general - reset - reset network settings Then try to look for available wifi networks again. If that doesn't work check your router has wifi switched on If that doesn't work it may be that your wifi antenna in the iPhone is faulty
8/26/2014 7:16:20 PM • Sony Ericsson... • Answered on Aug 26, 2014
How to turn on
Download and "File/Save As" to your Documents folder, the manual found here... http://www.manualslib.com/manual/163750/Sony-Ericsson-K310i.html
7/16/2014 8:03:29 PM • Sony Ericsson... • Answered on Jul 16, 2014
0answers
0answers
0answers
0answers
3answers
To delete the file
No worries, you can recover deleted files from mobile phone with mobile data recovery program, take a look at this one:how to recover data from mobile phonehope this helps.
8/24/2013 3:13:05 PM • Sony Ericsson... • Answered on Aug 24, 2013
0answers
Forgot pin on sony k301i
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
10/28/2012 11:28:54 PM • Sony Ericsson... • Answered on Oct 28, 2012
0answers
Sony Ericsson K310i Cellular Phone Logo
162 questions posted
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
says inactive sim
  • Cell Phones
