20 Most Recent Sony Ericsson Walkman W810i Cellular Phone Questions & Answers
it could be a fault with your phone.....but try to master reset it or reflashing the firmware.
Sony Ericsson... | Answered on Jan 19, 2020
you need windows media player in and this will change every song you have to mp3 select the file and copy it into the memory card if the songs are protected just dont download from itune take them from cd and rip the music with media player
Sony Ericsson... | Answered on Aug 23, 2019
ok my guess is that ur boyfriend has deleted the phone memory using the master reset umm on the left side there is a plastic slip flip it open and u have a memory card in there (depends how much the phone was (if it was cheep it wont) u should of got a little gray and blue card thing put ur memory card in the gray and blue card and if u have a card reader put it in the part where u put ur SD card in and it should come up as phone card i recommend not 2 use the cord because it is stupid
i hope it helps
Sony Ericsson... | Answered on Aug 28, 2018
I have the same phone, and was getting the same "Insert Smartchip" message.
I seem to have fixed it by taking off the cover on the back of the phone (the part with the Sony Ericsson name on it), taking out the large battery, and gently pushing the little blue Smartchip back into its chamber with my fingernail, as it must have come loose somehow. The Smartchip "clicks" into the chamber when it is in there correctly.
I put it all back together, turned the phone off, then back on. When it came on, it worked again.
Hope this helps!
Sony Ericsson... | Answered on Apr 14, 2018
Try to reset the phone back to factory settings.
Sony Ericsson... | Answered on Feb 02, 2018
cvv means master card validation code.
Sony Ericsson... | Answered on Aug 29, 2017
Well most phones have an option for a factory reset. Thats usually in the options or tools and settings menu of the phone. There is a possibility that the system memory is getting take up somewhere else and since the messages are the smallest data amount they are being mentioned. But I'm also not sure if older devices make that differentiation or not. Other than that, you may be able to find a replacement model online or you will have to upgrade because your phone is the point where it is just failing due to age.
Sony Ericsson... | Answered on Apr 26, 2017
Have you tried powering the phone off and removing the battery? Cleaning the charging contacts on the phone and the charger? Inspect the charging port to make sure there wasn't any damage from the fall. Then restart the device.
Hope that helps.
Sony Ericsson... | Answered on Mar 02, 2017
Go to Sitting> General> Security>Locks>
There is two option SIM protections and phone protections.
Any protection you want to add you can.
If this thread help you then don't forget to mark answer.
Sony Ericsson... | Answered on Jan 11, 2017
yes, on most sony ericsson phones, some files have been put there permanently and protected da files so they can't be deleted for example on my w910i there are 5 pictures wich are protected. don't worry nothings wrong with ur phone. i have no clue y they do dat but they do lol. i hope dis helped =)
its **** my phone done the same the shop said them phones get loads of problems like cracks through the buttons and freezing.
Sony Ericsson... | Answered on Dec 29, 2016
Please try it My Dear Brother:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sony Ericsson... | Answered on Dec 16, 2016
I need folder lock or phone lock software for sony ericsson mobile W810i (java software) THANKS
Sony Ericsson... | Answered on Nov 22, 2016
hi mate i wont to lock my folder lik music,pictures and videos but i dony have the program on my phone can please help me??????????????
Sony Ericsson Walkman W810i Cellular Phone Logo
1,560 questions posted
Top Sony Ericsson Cell Phones Experts
Ekse
Zaid Anarwala
Zaid Anarwala
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
inactive sim
  • Cell Phones
