20 Most Recent
Nokia N76 Cellular Phone Questions & Answers
Unpairing bluetooth headset without mobile???
You may be having compatibility issue instead of what you suspect may be wrong with both your phone and the Bluetooth headset your friend gave you.
Well, there is no such thing as a Bluetooth headset being permanently locked in to a phone.
As long as there is an open 'visible' Bluetooth connection option and there are devices in range ready to pair, the process to pair starts.
Whenever there are incompatibility issues, pairing two devices using Bluetooth becomes a hassle.
1/8/2018 6:57:54 AM •
Nokia N76...
Answered
on Jan 08, 2018
Pleace halp
If you do not need to keep anything on your phone ....Pictures, text messages and such then i would suggest to reformat your phone. Go into your phones settings and down towards the bottom should be back-up and reset or restore click on that and click factory reset. This will erase everything on your phone and factory reset it like the day you bought it. That should free up tons of space and just pick and chose what you wish to add back on to it.
10/25/2017 1:07:33 AM •
Nokia N76...
Answered
on Oct 25, 2017
Format code key
dial from keypad : *#7370#enter code : 12345your cell is starting formating.done..!! enjoy.
6/23/2013 3:05:44 PM •
Nokia N76...
Answered
on Jun 23, 2013
MY NOKIA CELLPHONE DIDNT WORK PROPERLY
Hi:First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
1/3/2013 11:52:59 AM •
Nokia N76...
Answered
on Jan 03, 2013
My phone nokia n76 is shorted what can i do
Hi thereBasically the only thing you can try is to let the phone dry out. Take out the battery and place the phone in a container filled with 1 cup of rice. Place the phone in the container, and seal the container for at least 24 hours. Also, make sure that your battery is still functional. You need to understand, that once the phone gets that amount of water damage it is very unlikely to get it working again, so the suggestion given is only a suggestion.Let me know if you have any further questions.Kind RegardsLock123
6/20/2012 8:56:16 AM •
Nokia N76...
Answered
on Jun 20, 2012
Lock code
Hi if the phone is asking for the code as soon as you switch it on then i can help you and give you the master reset code witch will give you acess to the phone if you have entered the code wrong more than five times then the phone will hard locked and youll need the flash lead and unlocking software
But if you want the master code then give me your imei number then i can generate your master code.
Your imei number is on the back of the phone under the battery and looks like 12345/1234/14546
Once i have this i can generate your master code for you ok
4/4/2012 1:45:02 AM •
Nokia N76...
Answered
on Apr 04, 2012
Phone start up failed please contact your retailer
try to do hard formatting to restore to factory settings, here's you need to do..
1. switch off your phone
2. remove sim and memory card..
3. press buttons 3, call key and * at the same time and switch on your phone without releasing the 3 buttons until you see nokia logo and hard formatting message.
good luck.
11/17/2011 11:23:59 PM •
Nokia N76...
Answered
on Nov 17, 2011
Bluetooth handset n76 pass code
Hi.
Here let me give you some hints.Generally we use to enter 123 or 000.But, sometimes this does not work, at list you can try.Good luck Thanks for visiting fixya
9/26/2011 9:30:18 AM •
Nokia N76...
Answered
on Sep 26, 2011
How to open n76 camera if i supposed to open the
sir, you need to track down the problem of your phone... check it in software try to write a CAMERA PM.. if not working try to dismantle your phone and check the camera.... and last but but not the least check the flex cable of your phone.... maybe this can help...
8/13/2011 3:28:11 AM •
Nokia N76...
Answered
on Aug 13, 2011
