20 Most Recent Yamaha RX-V773 Questions & Answers
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Yamaha RX-V773 | Answered on Apr 28, 2013
Hi Andrew Smith, as you comment, the problem would be in the remote control
You can do a test to see if the remote control is broadcasting
You put the camera of your cell phone focusing on the emitter of the remote control, press any key on the remote and through the camera you will see that the emitting LED turns on (this happens through the cameras of the cell phones detect infrared rays, our view can not do it directly)
With this method you can check if they are emitting each key of the remote control
If you don't emit, you can try cleaning the internal contacts
Try to carefully disassemble the remote control
Separate the plate and the rubber template from the keys, clean the latter with some neutral soap, removing the grease that forms in the contact area, on the other hand, clean the plate with a cloth dampened with a glass cleaner, NO USE ALCOHOL in any case, let all parts dry and reassemble
Take the test and comment
Greetings Franco Dosil
Hola Andrew Smith, por lo que comentas, el problema estaria en el control remoto
Puedes hacer una prueba para ver si el control remoto esta emitiendo
Colocas la camara de tu celular enfocando al emisor del control remoto, presionas cualquier tecla del remoto y a traves de la camara veras que el LED emisor se enciende (esto sucedepor las camaras de los celulares detectan los rayos infrarojos, nuestra vista directamente no puede hacerlo)
Con este metodo podras comprobar si estan emitiendo cada tecla del control remoto
Siencuentras que no emiten, puedes probar limpiar los contactos internos
Trata de desarmar con mucho cuidado el control remoto
Separa la placa y la plantilla de goma de las teclas, limpia esta ultima con algun jabon neutro, sacandole la grasitud que se forma en la zona de contactos, por otro lado, limpia la placa con un pa?o humedecido con algun limpiador para vidrios, NO USES ALCOHOL en ningun caso, deja secar bien todas las partes y vuelve a armarlo
Haz la prueba y comenta
Saludos Franco Dosil
https://europe.yamaha.com/en/products/audio_visual/av_receivers_amps/rx-v367/downloads.html
Yamaha Audio... | Answered on Nov 10, 2019
Hi Tony mucci, to connect your Yamaha EQ-70 equalizer to the RX-661, you must use two double RCA RCA cables and the Line IN connection of the EQ-70, you go to the RX-661 MD / CD-R Rec connection and the Line Out connection of the EQ-70 you go to the MD / CD-R Play of the RX-661
This equalizer will work with the analog audio signals, but not with the digital ones
I hope you can connect it
Hola Tony mucci, para conectar tu ecualizador Yamaha EQ-70 al RX-661, debes utilizar dos cables RCA RCA dobles y la conexion Line IN del EQ-70, vas a la conexion Rec de MD/CD-R del RX-661 y la conexion Line Out del EQ-70 vas a Play de MD/CD-R del RX-661
Este ecualizador va a trabajar con las se?ales de audio Analogicas, no asi con las digitales
Espero lo puedas conectar
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Yamaha-EQ-70-Service-Manual.pdf
https://de.yamaha.com/files/download/other_assets/8/327618/RX-V661_G_en.pdf
Yamaha Audio... | Answered on Nov 04, 2019
(1)download yamaha rxv663 service manual.
(2)read p.152-154
(3)make sure your remote matches with remote ID.
how to check remote IR diode
(1)switch on mobile phone camera
(2)point it to remote IR diode.
(3)Do not take any photo & press any remote buttons.
(4)White light flash.
how to check IR receiver
(1)locate the front panel.
(2)find out IR receiver.
(3)find an analog multimeter with 0.5V selected.
(4)black probe to ground, while red one to IR pin.
(5)press any remote button.
(7)deflection occurs
Yamaha Audio... | Answered on Nov 03, 2019
You have this backwards. The remote control is the source of the codes that apply to your Yamaha amplifier.
Yamaha Audio... | Answered on Oct 30, 2019
"My Yamaha receiver RX v575 will not power up it has a blinking red light when trying to power up "
Never press power button more than 3 times. Your amp will be locked, otherwise.
(1)Download RXV575 service manual.
(2)Read P.25 to 29 to see if protection occurs.
(3)Read P.31 and follow the diag steps.
(4)If I protect, check all power transistors,two
0.22Ohm resistors and biasing circuit such as
all components connected to Q2022 of front L channel, on P.108.
(5)If dc protect, check if DC comes out from speaker terminal, opening metal cover required.
(6)If thermal protect, replace a thermal sensor.
(7)If power supply problem, ps prt, check all
power supply circuits, including regulators and
caps.
Yamaha Audio... | Answered on Oct 25, 2019
Try this:
https://seventrumpet.com/reset-yamaha-aw4416-digital-audio-workstation/
Yamaha Audio... | Answered on Oct 20, 2019
Hi Bryan Fenwick, if your Sky + HD Box-Wifi-2TB, has a unique audio output and is an optical type (Fiber Optic), you will not be able to connect it to your Yamaha CRX-D430, because it does not have such inputs , the fiber optic connection you have, is an output of the compactera
You should buy an audio signal converter by fiber optic to audio signal, L R, with RCA
Hola Bryan Fenwick, si tu Sky+HD Box-Wifi-2TB, tiene una unica salida de audio y es tipo optica(Fibra Optica), no vas a poder conectarlo a tu Yamaha CRX-D430, por que no tiene entradas de este tipo, la conexion de fibra ptica que tiene, es una salida de la compactera
Deberas comprarte un conversor de se?al de audio por fibra optica a se?al de audio, L R, con RCA
https://uk.yamaha.com/files/download/other_assets/2/325162/CRX-D430_B-1.pdf
Yamaha Audio... | Answered on Oct 16, 2019
In some old model av-amp, if the sampling freq. is 96KHz or
above, av-amp confines its playback in 2 channels only.
Check the sampling input source is 96KHz or not.
Or perform this test
(1)Download htr6130 service.
(2)Start the self-diag test
(3)follow the instructions written on p.25 to 33 to do the tests.
Yamaha Audio... | Answered on Oct 14, 2019
Hi Terry Fraser, for what you say, you could have problems in the speaker outputs or power supply
Try disconnecting all the speakers from the back panel of your Yamaha and test if it does the same
If you do, it is safe source and output failure
If you don't, check all the cables and connections on the speakers well and reconnect one speaker at a time.
Comment the results
Regards Franco Dosil
Hola Terry Fraser, por lo que comentas, podr?as tener problemas en las salidas de parlantes o fuente de alimentaci?n
Prueba desconectar todos los parlantes del panel posterior de tu Yamaha y prueba si hace lo mismo
Si lo hace, es seguro falla de fuente y salidas
Si no lo hace, revisa bien todos los cables y conexiones en los bafles y ve re conectando de a un bafle por vez
Comenta los resultados
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Yamaha-HTR-5890-Service-Manual.pdf
Yamaha Audio... | Answered on Oct 08, 2019
Yamaha RX-V773 Logo
9 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
message volume fixed
  • Audio Players & Recorders
