20 Most Recent
Samsung SGH-T309 Cellular Phone Questions & Answers
How to open the lock of samsung sgh t 401g
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I know a site which unlocks SAMSUNG mobile phones for free
and that is
http://www.mobile-unlocker.com/
I am not clear with restore no.
What video formats are supported
Here is a video for unlocking your phone. From what I have read, your phone will not support any video format. The audio format supported is MP3. Here is a spec sheet. https://theinformr.com/cell-phones/samsung-t401g/#specs
I need a PUK code for my SGH-T309
A
request for a PUK code ("Personal Unlocking Key") will appear on your
phone if your SIM card PIN code is entered 3 consecutive times
incorrectly.
Your SIM card will then become
"PUKed" or Blocked. This is a security measure to protect your service.
You
need to call the Customer Service department of your cell phone
provider and they will give you the PUK code which will unblock your SIM
card.
How to delecte recent logs
These steps should be more or less similar.
- Press the OK button for Menu
- Select Recent Calls, using the navigation keys
- Select All (4)
- Select the Recent Call type, using the navigation keys, from the following:
- Missed Calls
- Received Calls
- Dialed Calls
- All Calls
- Highlight desired Recent Call, using the navigation keys
- Press the right soft for Options
- Select either Erase (2) or Erase All (4), using the navigation keys
- Highlight Yes, using the navigation keys
- Press the OK button to confirm call log deletion
Let me know if you need further help.
Good Luck.
Thanks for using
FixYa.
How do i get the " @ " for a email addy
Hello b109874,
There are a couple different ways to get your symbol. Here is the best (and easiest):
- Press the 1 key when you come to the part of the address that needs the @ symbol. It should display. (You may need to press 1 several times to get to the @ sign)
Please post a reply if this does not work for you and I will give you another solution. Thanks for using FixYa!
Edward
Samsung SGH T309 IEMI: 35783500 247603 2 02,
it will automatically change to the band frequency that is being used by the sim card. There's no need to set it manually as long as your phone support that frequency. Be sure that in India there is a network provider the will work for your type of sim.
I purchased PDA Hp Ipaq h5550 from usa. i am unable to use it in india .sim is not getting detected by phone.
try this
*2767*3855# let it reboot,but careful with this code it is eprom full reset,
then enter...
- *7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
- #7465625*638*00000000# (to permanently unlock the phone)
check the lock status...1) select D500 with D500 cable and press mobile info.
2) Use key 2.
3) With no SIM inserted,
4) enter: #7465625*638*[Key2]# to unlock
OR (if not success)
use this code
*7465625*638*00000000#
100% successfull trick unlock and ENJOY don,t forget say thx and please give me ratings
- *#7465625#
Original user had a password set
You have to take it to a repair / service shop where they will have to retrieve the code from the phone using a unlock software. Please don’t get caught for online pranks. Cheers.
Puk code needed
HI,
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call your phone service company, they can retrieve the puk code from a database
for free.
In your case you need to contact your SIM card phone provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone should not ask for the PUK anymore.
thank you,
Password problem sam-t309
*2767*3855# - Full EEPROM reset
ths is the full eeprom reset code... this will reset the all the password to default password but eveything in the phone memory will get erased ....
