Hi there I have an
follow this steps steps to upload your picture from your phone to computer.
1.Plug one end of the USB adapter into the phone, and the other end
into an available USB port of your computer. Look to the bottom right
of the screen and you should see an "Installing Driver..." window pop
up. Wait a few minutes to allow the computer to look for a driver for
your phone
2.Look for a window to pop up that tells you "Driver
was successfully installed." If it never comes up, or instead a window
pops up that says "Driver was not successfully installed," it means your
computer did not recognize your cell phone. In this case, you'll need
to look for the driver. If it did install, skip ahead to Step 5.
3.Install the driver by double-clicking on it. Before
you do this, make sure your cell phone is unplugged. After you've
installed the driver, plug in the cell phone, and it should be
recognized
4.Go to "My
Computer." Look for a new drive that has either the brand/model of the
cell phone in the name, or simply a picture of the cell phone on the
drive. It will probably have the drive name F:, I: or G:. Double-click
on it.
5.Go to Start > File > Settings >
Folder Options and select to enable hidden files and folders to be
shown. Then go back to your cell phone's folder and look around. You
should see a folder with the name "Pictures," "Photos," "images" or a
similar name. Double-click on it, and you should see all your cell phone
images.
6.Select images and right-click "Copy."
Then go to your desktop and create a new folder by right-clicking and
selecting "New Folder." Open up this new folder, right-click and select
"Paste." Your images will then be copied from the cell phone to your
computer where you'll be able to access them any time.
Take care.
