20 Most Recent
Samsung SGH-E330 Cellular Phone Questions & Answers
Export pics
if your phone came with a data cable . plug it in your phone and then pc. download the samsung kies software from samsung's offical site and you after connecting your phone you will see there a option to import photos. but if your phone didn't came with a datacable you can not transfer them directly to a pc.
but if your phone has bluetooth. firstly send them to a phone which supports connection to pc and has bluetooth. and then transfer from there.
C6112 sin lock password
hi are you looking for sim unlock code for your samsung c6112 mobile then visit
wickedunlock.com here they ask you the country and the network name to which your mobile is locked then the imei number of your mobile .finally they send you codes to unlock your mobile.
Samsung e330 limited service
Limited Service shows up on my E330 when I'm almost out of network range. I usually find when I move to a better location, the signal strength improves, and the message disappears.
What do i need to transfer my pictures from my
follow this steps steps to upload your picture from your phone to computer.
1.Plug one end of the USB adapter into the phone, and the other end
into an available USB port of your computer. Look to the bottom right
of the screen and you should see an "Installing Driver..." window pop
up. Wait a few minutes to allow the computer to look for a driver for
your phone
2.Look for a window to pop up that tells you "Driver
was successfully installed." If it never comes up, or instead a window
pops up that says "Driver was not successfully installed," it means your
computer did not recognize your cell phone. In this case, you'll need
to look for the driver. If it did install, skip ahead to Step 5.
3.Install the driver by double-clicking on it. Before
you do this, make sure your cell phone is unplugged. After you've
installed the driver, plug in the cell phone, and it should be
recognized
4.Go to "My
Computer." Look for a new drive that has either the brand/model of the
cell phone in the name, or simply a picture of the cell phone on the
drive. It will probably have the drive name F:, I: or G:. Double-click
on it.
5.Go to Start > File > Settings >
Folder Options and select to enable hidden files and folders to be
shown. Then go back to your cell phone's folder and look around. You
should see a folder with the name "Pictures," "Photos," "images" or a
similar name. Double-click on it, and you should see all your cell phone
images.
6.Select images and right-click "Copy."
Then go to your desktop and create a new folder by right-clicking and
selecting "New Folder." Open up this new folder, right-click and select
"Paste." Your images will then be copied from the cell phone to your
computer where you'll be able to access them any time.
Take care.
I have a puk block in my samsung E330 and i tried
PUK CODE:
PUK
code can be given only by your service provider which is specific for
each and every mobile number.
Contact
your sim customer care department over phone. Its free of cost
to get the pin or puk no. If you cant contact through your phone get
some other phone and contact them.
Go
to the nearest service outlet of your service provider they can also
help you.
There is no other go than the
above procedure only your service provider cangive it nobody else in
this world nor any software.
Go
to the below link and you can confirm that the above procedure works
and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
How can i download pictures from my samsung sgh e330 to computer?
You need a USB cable meant for your handset to connect to computer. Once you connect your handset to your computer , you can be able to copy pictures from mobile to computer. Go to samsung site to download the latest drivers and softwares for your handset. You will surely get a PCsuite for your handset.
Phone to Sim
To copy contacts from The SGH-E335 phone's memory to the SIM card follow the steps below:
- Press the right soft key for Ph.Book
- Choose Search (1)
- Select the contact you would like to copy to the SIM using the navigational keys
- Press the left soft key for View
- Select the number you would like to move to the SIM card using the navigation keys
- Press the left soft key for Options
- Choose Copy to SIM (6)
