20 Most Recent
T-Mobile BlackBerry 7105t Cellular Phone Questions & Answers
Mep unblocking codes
You can get the Mep unlock code for your Blackberry 7105t phone from
UnBBLock.com here you need to specify your country,IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.Using this you can unlock your phone from Network lock easily.
12/4/2013 7:36:09 AM •
T-Mobile...
Answered
on Dec 04, 2013
Iwant to hard reset this phone
A reset of a BlackBerry smartphone does not delete any settings or data.There are two options for performing a reset: a hard reset and a soft reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry
smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
5/22/2013 3:06:37 PM •
T-Mobile...
Answered
on May 22, 2013
Can u unlock my blackberry for free?
As
far as i know unlocking through unlock codes is the best.safe and
simple way.when i suffered with the problem my friend suggested me the
site from where i got my unlock code.....do not use wrong codes it may
damage your phone too.i know the site which gives good services.The site
is trustable.you can easily get your code from there its not free but
it as much cheap as free..click here to get your unlock code.
hope this helps...
3/22/2013 8:06:30 AM •
T-Mobile...
Answered
on Mar 22, 2013
I want unlock code blackberry
It is very easy to
unlock your blackberry 7105t. Go online .thousand of site available online. order your unlock code also called MEP unlock code.
after getting your unlock code . simply enter MEP code through your blackberry key pads.
after unlocking you can use your blackberry to any GSM network in the world.
i hope this will help you .
3/22/2013 8:04:25 AM •
T-Mobile...
Answered
on Mar 22, 2013
HOW DO I RESET MY PHONE
Hi Rob,
Reset, you mean firmware reinstall. Download the latest firmware drivers from Blackberry.com and then install those drivers via the Desktop Manager on your PC.
I hope this helps,
Thanks.
8/17/2011 11:59:55 PM •
T-Mobile...
Answered
on Aug 17, 2011
How to reset my blackberry 7105t
Blackberries use a method called "Wipe Handheld" to restore everything to factory settings. Here is the method
To wipe the handheld data, go into Options / Security / General Settings, click the wheel and select "Wipe Handheld".
8/17/2011 11:58:10 PM •
T-Mobile...
Answered
on Aug 17, 2011
Unlock blackberry 7105t
ya I can help you Don't worry............. my friends mobile has alsolocked
and after searching in google and reading forumswe found this site working good
they delivered code at right time
customer care was good
so you can also try it Click Here
good luck
6/23/2010 11:38:31 AM •
T-Mobile...
Answered
on Jun 23, 2010
7105t Blackberry is not switching on
when a phone does not come on, there are two area that you will need to check where the fault is from:
the battery,
and
the phone board.
The cell of the battery might be too weak to power the phone, so you need to check if the battery is really charged or the battery on the cell is finally dead and will need to be replaced.
For the phone board, the phone board might be dead and will need to be restored back by flashing the phone.
Flashing the phone will restore back the phone and it will start working normal again.
Have a nice day.
3/25/2010 1:43:09 PM •
T-Mobile...
Answered
on Mar 25, 2010
Accessing 7105t Blackberry e-mail on a PC
No unfortunately it is pushed technology straight to your device.
If you get another blackberry you can transfer your email accounts to the new blackberry retaining use of the mail account
2/22/2010 5:17:45 PM •
T-Mobile...
Answered
on Feb 22, 2010
Set up voicemail
Depending on the carrier it can be a little bit different.
Basically you need to dial the voicemail number from your cell, most
commonly 123. After this an automated machine will guide you through
the setup.
Hope this helps,
Joe
2/19/2010 10:08:59 PM •
T-Mobile...
Answered
on Feb 19, 2010
