20 Most Recent
Memorex MVDR2102 Questions & Answers
Memorex mvdr2102 no power
Other than a fuse being bad inside the unit weigh the cost of repair versus a new unit, most of the time if a inexpensive unit better to just replace it than fix it.
Memorex DVD Player
hello...please contact her dealer and try to replace the recorder if ther's a warranty...if not refere to the user manual.,and carefully read it regarding first useage...please tell me how it went...good luck...Ron
When i put in a certain disc, it says unknown disc
Hi...
Try a cleaner disc..Walmart and target sell them.
Or. open the drawer,unplug the AC with drawer open and get a can of dust-off compressed CO2 ( walmart or radio shack) and shoot it into the housing behind the drawer facce
USER GUIDE
http://www.memcorpinc.com/manuals/MVDR2102A_11-02-06.pdf
Interface error! Trun off the power
Okay...sounds like you have a lot of signal splitting as well as devices that may also weaken your signal. With digital cable, you won't see snow or what would be a dead give-away to a weak signal. Only analog signals do that. Digital signals give you crisp clear picture or they drop out.
Try taking the cable directly from the wall to the DVD-Recorder. If you are able to watch channels and manipulate the device, then you can start from there as the source is good and the recorder is good.
Try to place the DVD-Recorder after the first splitter and see if you still receive stable signal. You'll probably need to leave the unit in this part of your A/V chain.
It really sounds like you need a signal amplifier for all the splitting you've done, or to re-work your A/V stack into something more manageable. It is entirely possible that the built-in tuner of the new DVD-Recorder is not as sensitive as the old unit.
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
