20 Most Recent LG RC199H DVD Recorder/VCR Questions & Answers
2answers
Will not read dvd's
The lazer is foulty.
3/12/2022 7:57:34 PM • LG RC199H DVD... • Answered on Mar 12, 2022
2answers
Every problem that everyone has had with an lg
we have 2 choices
1 send it to lg with a nasty letter2 throw it in the trash ane dont buy LG
3/11/2022 5:00:59 PM • LG RC199H DVD... • Answered on Mar 11, 2022
2answers
I have an RC100H that keeps opening the DVD/CD
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
5/18/2020 9:27:22 AM • LG RC199H DVD... • Answered on May 18, 2020
Rewind vhs on lg rc 199h
Let the tape play all the way through and It will rewind on its own.
12/10/2018 3:55:16 PM • LG RC199H DVD... • Answered on Dec 10, 2018
2answers
Disc won't eject, play, turn off- only screen is initial lg logo
You may have to replace the lens on the player. O replace the entire DVD player. You may be able to find one online. be sure to give all the information possible.The problem is that the lens is not reading the digital information.
8/11/2014 9:10:30 AM • LG RC199H DVD... • Answered on Aug 11, 2014
0answers
0answers
Need manual
Be the first to answer 12/30/2013 6:14:50 PM • LG RC199H DVD... • Posted on Dec 30, 2013Be the first to answer
0answers
2answers
My dvd player will not reset, per manufacturers
I have the exact same problem, mine has been out of commission since this spring. I just got out the old RCA and plugged it in at that time. Now I have time to mess with it and it looks like I spent $300 plus on a very poor product. LG support just says it is discontinued and no help. No more LG products for this guy or his family.
12/22/2012 11:30:13 PM • LG RC199H DVD... • Answered on Dec 22, 2012
I get scrolling ghosting in the background. My tv
check scart fixings (in fully) and replace with shielded cables. Cause: signal leakage from unshielded inner cables.Just replaced my scart cables and this happened. Went back to old cables and it went. Cables returned to shop.
11/7/2012 5:34:07 PM • LG RC199H DVD... • Answered on Nov 07, 2012
2answers
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Thanks for using FixYa.
10/8/2011 5:38:35 AM • LG RC199H DVD... • Answered on Oct 08, 2011
My lg allways says it can't recognize disc.
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
  1. Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
  1. Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
  1. Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit motor is commonly the caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Please rate my help.
Thanks for using fixya.
5/24/2011 4:41:44 PM • LG RC199H DVD... • Answered on May 24, 2011
Need manual for RC199H
you can find the manual for your product here:
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=RC199H&matchedModelCode=1000001152&searchEngineModelCode=RC199H&initialTab=documents&targetPage=support-product-profile#
you have to install the DjVu reader, is listed in the same page.
Hope this helps, bye
3/10/2011 1:15:06 PM • LG RC199H DVD... • Answered on Mar 10, 2011
LG RC199H DVD Recorder/VCR Logo
71 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
every problem everyone lg
  • Televison & Video
