20 Most Recent
HP Designjet Z6100 InkJet Printer Questions & Answers
HP Z6100 error code 79:04
79.04 is a system error like ablue screen in windows. The troubleshooting process is very complex. Your best first step would be to disconnect any data cables and restart. If the machine comes to ready then it may be that you are sending data with either a corrupted print job or the wrong driver. If it errors even with the data cable disconnected then you will probably need to reset the eeprom. Make sure that the formatter is seated properly and all components on the formatter are seated properly.
Haw i can reset hp djz6100
Please explain what problem you are facing and what information you want to reset
Basic reset can be done from the front panel with one small hole find just below the cancel switch, press it once to reset plotter
HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Colors and photos do not
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Hi
I have z6100, just
Hi, Try taking a damp lint free cloth and cleaning the rails that the carriage moved left/right on. You will probably find the carriage rails are dirty.When the rails are clean, oil them lightly with silicone oil. You should also squeeze a little oil on the foam pads that are on the left and right of the carriage assembly. This keeps the machine lubricated.If this does not solve your problem then probably the line sensor on the machine needs replacing.Best regards
Banner Stands
