20 Most Recent Kyocera FS-3900DN Laser Printer Questions & Answers
Drum unit non- installing error
The drum unit is not installed or not installed properly. You must have knocked it loose.
Install the drum unit (See page P.1-5-10).
Kyocera... | Answered on Oct 08, 2019
i have 7410 error call service. i tried to clean everithing en replaced the tone is almost full- still getting the error message.hat can i do. (fs-3900dn)
Kyocera... | Answered on Sep 17, 2018
Defective Fixing Unit... Poor contact in the thermistor connector terminals, bad thermistor, broken heater lamp wire or some other contact problem related to fixing section. If it is possible, check with another Fixing Unit.
Kyocera... | Answered on Mar 20, 2018
You first need a HEPA vac. Toner is considered a carcinogen.
Kyocera... | Answered on Feb 03, 2018
6000 Broken fuser heater lamp wire
The temperature does not reach 100°C/
212°F after the fuser heater lamp has
been turned on continuously for 30 s.
30/31 ppm printer (EUR/USA model):
The temperature does not rise by 1°C/
1.8°F after the fuser heater lamp has
been turned on continuously for 5 s during
printing.
35/37 and 45/47 ppm printers (EUR/USA
model):
Fuser thermistor M detection
temperature does not rise by 1°C/1.8°F
after the fuser heater lamp has been
turned on continuously for 10 s during
warm-up or at standby.
Fuser thermistor S detection
printing.
Poor contact in the
fuser thermistor M
connector terminals.
Reinsert the connector (See page P.1-5-19).
Fuser thermistor M
installed incorrectly.
Check and reinstall if necessary (See page
P.1-5-19).
Thermal cutout
triggered.
Check for continuity. If none, replace the
thermal cutout (See page P.1-5-19).
Fuser heater lamp
P.1-5-19).
Broken fuser
heater lamp wire.
fuser heater lamp (See page P.1-5-15).
Kyocera... | Answered on Jan 23, 2017
The user name is : Admin
password is : Admin
if the command center asked for password only then it is : admin00
Case sensitive for all.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Kyocera... | Answered on Apr 24, 2016
Error 7410 is drum unit not installed properly if you open the side door and push the the drum unit back in to place it probably just popped out of position a little bit
Kyocera... | Answered on Apr 11, 2015
Drum unit non- installing error The drum unit is not installed or not installed properly. The drum PWB EEPROM does not communicate normally.
Kyocera... | Answered on Mar 16, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Kyocera... | Answered on Mar 06, 2015
Power off the printer, open left door and press in the drum unit (press in the area just above the square button) until it clicks into place. Close the door and power on.
Kyocera... | Answered on Oct 30, 2014
sounds like invers is turned on which switches everything black will be white and white will be black try to find this seting and turn it off
Kyocera... | Answered on Aug 21, 2014
user:Admin pass:Admin User:admin pass:admin00
Kyocera... | Answered on Aug 11, 2014
are you asking for the password the default passwords are either Admin or admin00 that is for the web page on the machine its usally Admin or the speed of the mACHINE PLUSE TWO zeros
Open the left cover and push the drum unit inside (above the waste toner bottle) to lock. You will hear a sound like "click". If you cannot push the drum unit, you can first remove the developer unit.
Kyocera... | Answered on Jul 22, 2014
It might be the main charger (MC-310 or MC-320) or the ground of the developer unit. In the first case, just remove the roller from the drum unit and clean it. In the second case, you have to remove the engine pwb (the board under the printer) and check the spring which grounds the developer unit.
Kyocera... | Answered on Jul 15, 2014
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Kyocera... | Answered on Apr 30, 2014
Kyocera FS-3900DN Laser Printer Logo
189 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
error call service 4000 00433933
  • Office Equipment & Supplies
