20 Most Recent Durabrand PDV-705 Portable DVD Player Questions & Answers
have you tried a cleaning disk and make sure the movie disks have no finger prints on them that will stop it from loading.
Durabrand... | Answered on Jan 03, 2020
Check and make sure the laser eye is clean and clear of dust and smudges. With player OFF, blow across laser eye. Try cleaning with soft dry Qtip. Otherwise you probably have a bad laser drive or bad drive ribbon cable.
Durabrand... | Answered on Jan 02, 2020
simple some actaully most portable dvd players just arent made to play copys or duplicates becaues they do not have the software for that kind of disc. so they instead can only play origanals dont worry my portable dvd player does this too
Durabrand... | Answered on Jul 11, 2019
i have a manual that i could copy from, 25 cents a page plus shipping (english version is about 16 pages) tking
Durabrand... | Answered on Sep 12, 2017
I would go on line and look.
Durabrand... | Answered on Jun 18, 2014
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Durabrand... | Answered on Jul 14, 2013
Check the DVD player ,and you can also look theinstrutions of it .
Durabrand... | Answered on Mar 15, 2013
try going to the companies website or either try ebay. ebay nay be cheaper!
Durabrand... | Answered on May 24, 2012
Off is best since if on it will charge much slower
Durabrand... | Answered on Apr 25, 2012
If a portable, could be no charge or bad battery---output voltage is marked on the charger and can be tested with a meter---if voltage and battery are good (most units will work with the charger hooked even if battery is bad) then the unit has either a damaged jack where charger connects or has a power supply problem inside it.
Durabrand... | Answered on Apr 24, 2012
I fixed one with this problem today. The problem was in the switch that is depressed when you close the lid. That switch turns the the screen and the sound off when the lid is closed, and back on when you open it.
I has to remove the back cover, spray the switch with contact cleaner (and immediately press the switch in and out several times quickly to help the contact cleaner to work). This solved it. Put the cover back on and all is well.
Durabrand... | Answered on Sep 18, 2011
Durabrand PDV-705 Portable DVD Player Logo
167 questions posted
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Durabrand Televison & Video
Most Popular Question
durabrand portable dvd player 7in tft
  • Televison & Video
