20 Most Recent
HTC S710 Smartphone Questions & Answers
MY HTC S170 's battery was empty so i connected it
Sounds like a hardware failure, it could have been due to the low battery, it could have been due to something just failing while charging, but i doubt there is a quick fix at this point from what your describing. The only other thing i could think to try would be pull out the battery and leave it out overnight then try again, that would hard reboot the phone, if it still behave the same its time for a new phone as it would likely cost more then its worth to do anything else to it.
1/11/2018 9:30:58 AM •
HTC S710...
Answered
on Jan 11, 2018
How to install software
I would take this to your providers store front. They will be able to fix this quick and free.
11/29/2015 6:44:26 PM •
HTC S710...
Answered
on Nov 29, 2015
How to write message in hindi/slang
if your phone language doesn't contents those language then you cannot write in that language. that language cannot be added after the mobile manufacture
2/16/2015 10:30:34 AM •
HTC S710...
Answered
on Feb 16, 2015
Unlocking keypad lock
To lock the keypad so that you don't accidentally call anyone, simply press AND HOLD the red "end call" button.
To release the lock, press the left menu button, then hash (#)
Please rate after seeing my solution
5/8/2013 8:53:28 PM •
HTC S710...
Answered
on May 08, 2013
I have language problem.I bought
u need just to change the normal language to english then u can go to settings and regional settings and change it to english
but if u want complete english windows then
uneed an english rom for ur pda it is available on www.htc.com otherwise u can get it from xda developers tell me if it helps pls vote
or last option is reset ur device it will give u english option at the startup i think definately
5/6/2013 11:59:48 AM •
HTC S710...
Answered
on May 06, 2013
Hanging when it restart give me the solution
mY Dear:First:restore your Phone SettingsIF Restart problem not Solved So Secend Option:Please Format Your Phonewe can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.*#7370# or *#7780#Default security code is 12345release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card.If Problem Not Solved SoVery Best Solution:flash new software install in the phone problem will solved quickly
10/26/2012 12:52:33 PM •
HTC S710...
Answered
on Oct 26, 2012
Connet to pc
just open the following link and download htc pc suite and connect your phone to pc. click on free user and download.
http://rs348.rapidshare.com/files/299303018/HTCPortal.apk
2/4/2012 7:06:16 AM •
HTC S710...
Answered
on Feb 04, 2012
Pc connect
http://www.software112.com/search-program/1/htc+s710+pc+suite.html
Please use the above mentioned link and download the pc suite. After that you can connect your HTC phone to pc via USB data cable
2/4/2012 6:40:56 AM •
HTC S710...
Answered
on Feb 04, 2012
