You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. This will erase the internal memory of the camera and allow your card to work.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
1- If you want to format it by keeping in digital camera then follow the given procedure:-
Put the SD card into your digital camera and then turn the power on.
Press the button on your camera to bring up your recently shot
photographs.
Press the "Menu" or "OK" button on the camera to bring up the photograph
options. Choose the option that says either "Setup" or "Options."
Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
2- You can also format it by connecting it to computer through card reader, For it follow the given procedure:-
Turn on your computer and put the SD card into the card reader slot on
the front of your computer or the external card reader attached to a USB
port. Wait to see if your operating system automatically opens a window
prompting you for information. Click on the option to "Open a folder to
view files" if the window pops up.
Click on the "Start" button if your operating system does not
automatically prompt you to open a folder. Choose the "My Computer"
option to bring up a new window.
Right-click on the drive bay for your card reader, and then choose the
option that says "Reformat" from the pop-up menu. Click on the option to
set the formatting to "FAT16" if you receive a separate pop up window
asking you which file system to set the card to.
You can also get help from the given video, if you choose second option
If
you think this solution helps you then your token of appreciation in the
form of Rating as Four Thumbs and a testimonial will be esteemed. Thanks you for using FixYa!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Please remove the SD card and check if the small lever found on the side is pushed to lock position. If so push the lever to unlock as the card will be released of the write protect safety.
If you have pictures on the memory card, don't choose format...this will completely erase the card. It appears to be asking you if you want to save the pics to the computer first. Do you? If so, connect the camera to the computer and choose yes. Otherwise, choose no. You could also try a camera reset. With no card in the camera, go into the menu and find "reset" and follow the on-screen instructions.
connect your cmaera with the given conneccting linking cord to the PC. The PC will detect your camera and ask for action --mostly.
If not you can click on the new device in My computer folder - new drive.
open this and the photos will be seen. You can copy and paste or send it by right clicking to the documents- my picture folder.
Alternatively you can take the memory card and download directly with the card reader slot - if present in you PC or laptop.
#1 Insert your ( memory card , flash disk , cellphone , .... ) into your computer. #2 Open up 'My Computer'. You should see it under the list of available drives. #3 Check its contents first to make sure that you have the right drive. #4 In 'My Computer', right-click on the drive and choose 'Format'. #5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place. #6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
enter Vivitar ViviCam 3720 user manual into your search engine and see lots of sites offering manuals. Could not see it on Vivitars site so must be an old camera.
