20 Most Recent Samsung YP-K3 MP3 Player Questions & Answers
You can download the EMODIO and MULTIMEDIA STUDIO software from the samsung website:
http://www.samsung.com/ae/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=&prd_mdl_cd=YP-K3ZB/MEA&prd_mdl_name=YP-K3ZB&srchword=YP-K3
Please install these and use for your player.
Thanks.
gylacz
Samsung YP-K3... | Answered on Nov 27, 2019
Vista = not compatible with this player
I ve bought samsung mobile on 9-Nov-08, but there are some problem in the battery back up. so kiindly help me out that. pls resolve my issue.
Samsung YP-K3... | Answered on Nov 14, 2019
Follow this link:
http://www.samsung-eternity.com/index.php/topic,1692.0.html
Thnx
Sachidanand
Samsung YP-K3... | Answered on Oct 27, 2019
SOWTWARE SAMSUNG
F270
Samsung YP-K3... | Answered on Sep 30, 2019
go to the samsung website to there download centre and download the software..
http://www.samsung.com/au/support/download/supportDownMain.do
i had the same problem and i just downloaded from there website.
www.samsung.com.au
go to the support button and a drop down menu appears then go to download centre. follow the steps when the page loads
Samsung YP-K3... | Answered on Jul 03, 2019
Have either of you both tried downloading the drivers for the device?
I used the included CD which had also some software which I don't use... Drag&drop works for me!!
Anyway->
Try Samsung's site ---
http://www.samsung.com/uk/support/productsupport/download/index.aspx
Hope it helps...
Andy
Samsung YP-K3... | Answered on Jun 26, 2019
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing
You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add"button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing.
Step 3. Start Deleting Duplicates
After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_3.jpg For more details, check: How to Delete Duplicate Songs
Samsung YP-K3... | Answered on Apr 24, 2019
if your samsung does not work with your computer go on the net and, type samsung bluetooth repair down load. you will be helped
Samsung YP-K3... | Answered on Feb 18, 2019
Available from Samsung suppoort site along with firmware upgrade tool
Like most Samsung electronics, the software is the pits, yet the hardware is generally quite good.
If the Samsung YP-K3 MP3 player continues to act erratically, a reboot, or reset, may help. Resetting this device allows you to reinitialize your player without losing your files or device settings.
The Reset hole is on the back of the device, toward the bottom. Press one end of a straightened paper clip into the Reset hole gently. Then allow the Samsung YP-K3 MP3 player to initialize.
You may want to upgrade and if you have, this may be why the files were reset.
YP K3 SUPPORT SAMSUNG
Samsung YP-K3... | Answered on Jan 08, 2019
What model of Recevier do you own?
Are you just connecting Audio to the recevier? How are you connect the satelite?
Samsung YP-K3... | Answered on Jan 02, 2019
Overview for all models YP-K3 in USA:
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP01&searchWord=ypk3&searchInputBox=yp-k3&find_button=See+all+results
When having a product from another region, select your country on the left bottom page.
Using Windows Media Player 11
When viewing Library in WMP11 in full mode 'Create Playlist' first, before transferring it to the player:
More information about using Windows Media Player:
How to use WMP 10:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
How to use WMP 11:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Using Samsung Media Studio
Manual for the YP-K3 tells to use Samsung Media Studio for transferring files to the player, see from page 20:
http://downloadcenter.samsung.com/content/UM/200702/20070225090856671_YPK3-COMMON-ENGLISH0.0.pdf
Direct to the download for Samsung Media Studio:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=1848443&CDCttType=SW&ModelType=N&ModelName=YP-K3AB&VPath=SW/200712/20071220130654265_MediaStudio5_5212.exe
Samsung YP-K3... | Answered on Nov 26, 2018
Samsung YP-K3 MP3 Player Logo
702 questions posted
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
samsung nearest service center in
  • Audio Players & Recorders
