20 Most Recent Apple iPod nano Questions & Answers
3answers
Apple ipod nano 3rd genaration
you need to use itunes which is available freely from the apple website see http://www.apple.com/itunes Hope this helps
3/2/2024 6:16:30 AM • Apple iPod nano • Answered on Mar 02, 2024
3answers
How can i down load music on to my ipod
Hi ,
PLease download ITUNES from the apple website directly for free,
Here is the link for that
http://www.apple.com/itunes/download/
The only way by which you can upload songs to ipod is by ITUNES
Please rate this solution, THanks in advance
RNJ VINOD KUMAR
1/10/2024 9:46:35 AM • Apple iPod nano • Answered on Jan 10, 2024
2answers
Download to ipod
How Do I Download Songs Onto My iPod Nano?IPod Nanos are portable multimedia players that allow you to playback songs and other content (e.g. video) no matter where you go. They come in a variety of memory sizes such as 4GB or 16GB (gigabytes) and work with iTunes to upload songs. ITunes is the iPod default management program which allows you to upload songs to its library, create playlists and sync music on your iPod quickly and easily. This simple process will have you jamming to your favorite songs in no time.Downloading to an iPod Nano1Connect your iPod Nano to the computer using the USB cable. Launch iTunes if does not automatically launch. When you launch iTunes, it will display your iPod Nano on the left panel.2Add music to your iTunes library. Click the "File" button on the top menu and click "Add to Library." Locate the song you want to upload to your player and click "Open" to load it to your program.3Click the "+" button on the lower left panel to create a playlist. Type a name for the playlist and drag the uploaded file to it. To upload additional songs, repeat Step 2 and drag the uploaded additional songs to the created playlist.4Drag the songs in the playlist up or down to select the order in which the songs will play.5Sync your iPod Nano. Click the iPod icon on the left panel after importing songs and adding them to the created playlist. Click the "Music" tab and click "Sync music." Click "Select playlists, artists and genres" and select the playlist you created that contains the songs you want to upload. Click "Apply" to automatically sync and download the songs to your iPod Nano.6Click the "Eject" button and disconnect your iPod from the computer.Tips & WarningsClick "Music Store" if you want to purchase a music file. Search for the song on the iTunes store and download it to the iTunes library.
4/25/2023 1:37:30 AM • Apple iPod nano • Answered on Apr 25, 2023
21answers
Ipod not recognized by computer or itunes
I struggled with this issue for a while and finally found a post that helped me. Hold menu and the center buttons until the iPod turns off. Then, immediately hold the left and center buttons to pull up the iPod diagnostic menu. Scroll down to the option "Reset" and select it. My iPod was finally recognized by iTunes. Good luck :)
2/18/2023 12:59:45 AM • Apple iPod nano • Answered on Feb 18, 2023
2answers
Music that has been labeled "other" instead of "audio"
you are going to have to reload the music in a mp3 format for it to play
9/16/2022 2:43:57 AM • Apple iPod nano • Answered on Sep 16, 2022
2answers
Music wont show on Ipod, but does on Itunes
Please make sure that your music is in the proper format. It is best if it is in MP3 format. You can tell what format the music is in by right clicking on the music file and then clicking 'properties'. You can convert the files to MP3 by using the Media Player that comes with all windows computers. Hope that helps.
9/16/2022 2:38:36 AM • Apple iPod nano • Answered on Sep 16, 2022
2answers
Adding files from IPod Nano GB to work computer
IPod isn't compatible with Windows Media player. You have to use ITunes to manage your music files. Ipods use mp3, mp4, a protected form of mp4 unique to apple, and aac format. aac format isn't recognized by windows media player.
1/21/2022 2:48:46 AM • Apple iPod nano • Answered on Jan 21, 2022
2answers
Ipod
First I would suggest you make sure the iPod is connected correctly, and that you wait until the iPod has finished updating.
If you are sure of that, you can always restore the iPod to it's original settings.
(I would also suggest that you are using the most updated version of iTunes)
But before you restore your iPod, there are a few steps you can take to try and fix this problem.
If you can’t download a song or other item to iPod nano
The song might have been encoded in a format that iPod nano doesn’t support. The
following audio file formats are supported by iPod nano. These include formats for
audiobooks and podcasting:
 AAC (M4A, M4B, M4P) (up to 320 Kbps)
 Apple Lossless (a high-quality compressed format)
 MP3 (up to 320 Kbps)
 MP3 Variable Bit Rate (VBR)
 WAV
The most common is to reset the iPod. To do this:
  •  toggle the Hold switch on and off ( Set it to hold then turn it off again)
  • Then press and hold the Center and Menu buttons for at least 6 seconds untill the Apple logo appears.
If this does not work I would consider restoring. This means you will loose all your music,pictures, videos..ect. But from it sounds, you don't have anything on your iPod to loose.
update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
1/6/2022 3:34:23 AM • Apple iPod nano • Answered on Jan 06, 2022
2answers
How to download music from my pc to my ipot
You should install iTunes from http://www.apple.com/itunes/download/
Then plug in the MP3 player, and once iTunes finds the device, add music to it from the library you already have, or by purchasing music from the Itunes Music Store.
10/22/2021 3:34:07 AM • Apple iPod nano • Answered on Oct 22, 2021
5answers
Downloading
You need to use itunes as your music management software and ipod management software. You can download the latest itunes version at www.apple.com/itunes.
From here you can purchase items through the itunes music store, or add your own music by adding files from your computer, or putting a cd in your computer and coppying it into itunes so you can put the songs on your ipod.
Hope this helped,
Nathan.
9/17/2021 2:52:48 AM • Apple iPod nano • Answered on Sep 17, 2021
3answers
How do I transfer a playlist from I-Tunes to my I-pod?
Connect your iPod to computer, iTunes will detect the iPod automatically, then click iTunes menu "File -> Sync iPod", the songs will be transferred from iTunes to iPod. Or You may try this ipod transfer, it's an iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes. It can also help you manage multiple iPods on one computer or manage iPod on multiple computers, even copy music and video from iPod back to computer or iTunes. So you will not lose your iPod files even though you switch to a new iTunes library. My friends recommend it to me, it works pretty well. http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html Hope it helps. Feel free to email me if you need further help.
8/12/2021 6:15:36 AM • Apple iPod nano • Answered on Aug 12, 2021
2answers
Dowloading non itunes playlists already on computer to newipod nano
in your yahoo music jukebox you open the file you want to transfer to ur i-pod and right click it and sync it
8/12/2021 6:12:28 AM • Apple iPod nano • Answered on Aug 12, 2021
3answers
When I put my earbuds into my ipod touch only one side works
You need to get the headphone jack replaced from apple.
8/9/2021 1:18:21 PM • Apple iPod nano • Answered on Aug 09, 2021
2answers
When I plug my ipod into my computer, it doesn't
Maybe you should try this third ipod manager tool - Daniusoft iPod transfer:
Key-features:
1. Sync videos/songs from computer to iPod without iTunes ;
2. Backup videos/songs off iPod to computer smoothly ;
3. Transfer iPod video/music to iTunes .
I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well.
7/8/2021 6:00:23 AM • Apple iPod nano • Answered on Jul 08, 2021
3answers
How do i put movies or videos in my ipod 4GB??????
only 3rd generation iPod nanos can play video, and the video must be mp4, you can use itunes to sync video to ipod nano, just follow those steps:
1. Open iTunes and click "File" to add your videos to iTunes library.
2. plug in your iPod Nano to computer, then iTunes will detect your iPod Nano as a device.
3. Select your iPod Nano device on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply"
7/7/2021 9:54:43 AM • Apple iPod nano • Answered on Jul 07, 2021
4answers
How download free music for
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV. 1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio". 2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music. If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement. After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc. 1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window. 2. Import files to the software from computer in the following four-way: I. Drag and drop the music files into iTransfer directly. II. Click the button "Add" on the upper part which is beside the left sidebar. III. Click the button File > Add > Add File/Add Folder on the top right corner of the window. IV. Right click on the library and select Add File or Add Folder. 3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed. For more details, check: How to Download Music from YouTube to iPod music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-4-0_2.jpg
6/28/2021 6:09:49 AM • Apple iPod nano • Answered on Jun 28, 2021
2answers
I was given an ipod
You can only upload music to an apple ipod if you have itunes. Then you can put your music on there.
Its apples way of marketing.
6/17/2021 10:37:26 AM • Apple iPod nano • Answered on Jun 17, 2021
4answers
I have an ipod nano 8gb, i'm trying to put my
This ipod manage software can transfer the files from ipod to computer,computer to ipod,ipod to iTunes,ipod to iTunes, and iPod to iPod:
please click here for more details.
Hope this Helped!
3/12/2021 2:13:31 AM • Apple iPod nano • Answered on Mar 12, 2021
2answers
How do i upload my music to my nano ipod 4gb to my
Connect Your ipod to PC with USB cable.
If you have music in your PC directly copy to your ipod
-If you connect ipod to pc, it will automatically open ipod memory open and copy from your computer to ipod.
If music not in your PC, download from internet.
3/2/2021 7:26:55 AM • Apple iPod nano • Answered on Mar 02, 2021
2answers
Download music from my computer
If you want to download to your i pod,you have to use a i Tunes media player to enable you acess to i pod and transfer music into it.
If you don't have i Tunes software, go on net through google an search for i Tune downloads.
Download i Tunes and install,after installing connect your cable from your i pod to your pc.from there you can fnd your way out.good luck.
2/25/2021 7:01:11 AM • Apple iPod nano • Answered on Feb 25, 2021
Apple iPod nano Logo
6,769 questions posted
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
iPod Apple
  • iPod Apple
Most Popular Question
apple ipod display screen not working
  • Audio Players & Recorders
