20 Most Recent
Dirt Devil Breeze Bagless VacuumVacuum Questions & Answers
Belt keeps burning off
Be sure the brush roller spins freely. Tear apart the end caps and get the carpet string and hair out of it for better performance and longer belt life. Nothing much else it can be.
Why dirt devil breeze no power?
Hello! The Breeze is equipped with a thermal protector that will cause the vacuum to automatically shut off when it is overheated. This is most likely caused by a clog or a filter that needs to be cleaned or replaced. When the thermal protector is activated the vacuum will need to cool down before it will power back on. This can take up to an hour. Try these quick steps below to prevent the vacuum from shutting off again.
1. Twist off the end to the lower hose that connects to the brushes.
2. Use a wooden spoon to gently looses and remove any blockages in the lower hose.
3. Remove the pleated filter from the dirt cup. Tap the filter firmly against a trash can until the dirt stops falling. The filter should be replaced every 6 months.
I have included a link where you may go to purchase the F1 filter for your vacuum. If you still have questions please feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil. Thanks!
F1 HEPA Filter
How do I take the agitator end caps off?
Alliemay657: It sometimes takes a 2 grunt pull to remove the end caps and bearings from the agitator (called the beater bar). I have had to use a flat blade screwdriver to CAREFULLY pry the end caps and bearings from a beater bar. Be careful not to stab your hand with the screwdriver (It HURTS!!!) Once you get the end caps and bearings off, clean the hair and carpet fibers from the ends of the beater bar and bearings and end caps. If the bearings don't turn easily, dribble some rubbing alcohol on them (I use a spray bottle filled with alcohol) and spin them until they spin freely. Dry the bearings until there is no alcohol in them. Put a drop or two of light machine oil in each bearing (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure they spin freely. Now would be a good time to check the vacuum head and hose for clogs. Push the bearings and end caps back on the beater bar and reinstall the beater bar (with a new belt). Reinstall the foot plate, and your machine should run like new
