20 Most Recent
Dell Inspiron One 2020 All-in-One Desktop Questions & Answers
Error code 0x4001100200001005
"error 0x4001100200001005 if problems persists contact Dell support"
The reason you get a 0x400 error is because the OEM hard drive was replaced with a retail hard drive. OEM drives are "tattooed" or branded.. and the recovery media will search for it before installing. Prevents the spread (aka pirating) of OEM recovery media to computers that it did not ship with.
I got the same error when restoring an Inspiron 2330 Touch using the DVDs I created when the system was new.
In my case I had to boot to a Windows OS DVD, go into recovery console and open DISKPART
Perform the following steps to wipe the disk:
In recovery console, type DISKPART
At the diskpart prompt, type LIST DISK
Note the number of the disk you want to restore the OS to
Type SELECT DISK 0 (0 or whatever the number of the disk is)
It will say "Disk 0 is the selected disk"
Type CLEAN
When it finishes, exit, and retry the restoration.
Failed bios update
Check on the Dell site == it may be possible to 'boot' the Dell BIOS update utility direct from a USB stick even if nothing else is working ....
Display turns off and on
Do you have a video card? Sometimes when it is overheating (video card fan not working) it does that.
Otherwise try another video cable, maybe borrow from a friend.
How do I customize the keyboard sleep button?
It's in the Power Options. Click on your start button, and start typing in "Power Options". On the left hand side of the screen that pops up will be something titled "Choose what the power buttons do". Click on that. It will give you options for both the power and sleep buttons.
Blank screen on Inspiron 2020- computer gets power and boots up but I get a blank screen
If computer has an output for another monitor , plug extra monitor into it. If other monitor also does not work then the problem lies within the video circuits. If external monitor works then the hassle is with the lcd screen.
Either way it is not a cheap repair since it is an all in one product with proprietary parts. Add to that the labor factor and you might be looking at a new unit.
Cap lock download
Some Keyboards have the option to display capslock on screen. To check if you can, try this
- Open Control Panel. In Windows 8 you can access it by right clicking the bottom left of your screen, and clicking Control Panel.
- Double click Keyboard. The Keyboard settings panel should pop up.
- If you see a Keyboard Settings tab near the top of the panel, click it, and see if there is an option to display Capslock on screen.
You can try this 3rd Party software :
CAPSLOCK Notifier 1 1
Alternatively, Dell provides a driver to display capslock on screen, however it is for a different keyboard model, so I am not sure if it will work with yours.
http://ftp.dell.com/FOLDER00703639M/6/APP_IO_W7_A00_Setup-YPN75_ZPE.exe
