20 Most Recent Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Questions & Answers
2answers
I have a Bissell Proheat that sprays water for a
Hi Tom. It sounds like your ProHeat may have lost prime. I understand you've done some troubleshooting, but we have a terrific FAQ that will help you with the no spray.Here's the link: http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
1/12/2023 6:35:54 PM • Bissell 9500... • Answered on Jan 12, 2023
4answers
Shampooer tank not working
Most times there is a problem with the cap and insert at the bottom of the tank, part #2036675. Either that or the tank isn't sitting flush and down all of the way, leaving a gap. If this is less then 1 year, then it is under warranty.
11/5/2022 7:57:54 AM • Bissell 9500... • Answered on Nov 05, 2022
19answers
Bissel pro heat 2x wont spray any water
I had the exact same problem with my ProHeat 2. It would spray only through the hose attachment but not on the floor. Cleaning of the spray endings on the floor unit fixed my problem. Either soap deposits or dirt was clogging the spray endings. Here is what to do to clean up the spray endings:
1. Remove the water container from the bottom unit
2. Look up for two red plastic endings on the bottom unit
3. Using your fingers to clip sides of an ending, carefully remove it from its slot
4. Using pliers, release the clamp from plastic ending and remove the red plastic ending from the hose
5. Clean the ending
6. Put the ending back on the hose, slide clamp back on the ending
7. Insert the ending back in its slot
8. Repeat 3-7 for the other ending
That solved the problem for me!
1/12/2021 2:42:45 PM • Bissell 9500... • Answered on Jan 12, 2021
I think my bissell proheat 2x is plugged up with pet hair.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rrtjgh
10/23/2019 6:02:50 AM • Bissell 9500... • Answered on Oct 23, 2019
MY BISSELL PROHEAT WONT SUCTION
heatman101
ffuutr
5/30/2019 2:08:00 PM • Bissell 9500... • Answered on May 30, 2019
I have a Bissell proheat steam cleaner, the 9500
There is probably more gunk in there, the gunk can dry and break off in little shards which can get clogged up. You can try putting straight vinegar in it, try running it through and let it sit in there for a while to see if it can help loosen up and flush out the gunk.
10/17/2017 2:50:57 AM • Bissell 9500... • Answered on Oct 17, 2017
Bissell proheat 2x 8920 repair manual schematic of
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Bissell model by clicking the link below. Bissell 8920 User Manual You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/15/2017 9:39:52 PM • Bissell 9500... • Answered on Oct 15, 2017
Bissell 9400-4 repair manual
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Bissell model by clicking the link below. Bissell 9400 3 User Manual You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/3/2017 2:28:52 PM • Bissell 9500... • Answered on Oct 03, 2017
Can I use the Bissell 2x ultra on micrfiber?
Before using your Bissell on a microfiber couch, make sure to check the tags on the couch. Microfiber couches come in different "flavors." There's S, W, S/W and X. Using the wrong cleaning method can damage your couch. Here's an article that goes into more detail on what each code stands for and how to clean each one. Tips on Purchasing and Cleaning Microfiber Couches
9/4/2017 11:37:55 AM • Bissell 9500... • Answered on Sep 04, 2017
Bissell Big Green Carpet Cleaner has poor suction why?
Hello, this is Ava with Think Crucial. Most of the time the reason why vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. You may need to refer to your User's Manual for instructions and guide. You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
8/27/2017 2:45:18 PM • Bissell 9500... • Answered on Aug 27, 2017
0answers
2answers
Cleaning oriental rugs leaves lines on some rugs
Hey Jeff! Some Oriental rugs should not be cleaned with water. You may want to contact the manufacturer of the Oriental rugs regarding their care instructions.
4/5/2017 7:01:51 AM • Bissell 9500... • Answered on Apr 05, 2017
My bissell proheat pet won't spray through the
This worked for ours it had alot of little crystallized pieces in the valve cleaned it not water will come out bottom. Thanks!
3/19/2017 11:05:31 PM • Bissell 9500... • Answered on Mar 19, 2017
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,213 questions posted
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
will harm hardwood floor under area rug
  • Vacuums
