20 Most Recent Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Questions & Answers
My bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdghd
5/7/2023 7:36:45 PM • Bissell Carpet... • Answered on May 07, 2023
How to fix Bissell ProHeat 2X 8300 carpet cleaner?
heatman101
gkjkgj
5/7/2023 7:32:23 PM • Bissell Carpet... • Answered on May 07, 2023
How to replace bladder bag?
Videos. All questions should have make model (what it is) So this might be way off mark, but that's what happens when we guess. :>) https://www.google.com/search?q=How+to+replace+bladder+bag ..
10/17/2021 12:53:54 AM • Bissell Carpet... • Answered on Oct 17, 2021
My Bissell powersteamer has no spray releasing for
The nozzles on the bottom get blocked you can take them off and clean them out , Before you put them back run it with out the nozzles in to flush line.
2/1/2018 5:36:22 PM • Bissell Carpet... • Answered on Feb 01, 2018
Manual for a Bissell Powerlifter 1660
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Bissell model by clicking the link below. Bissell 1660 User Manual You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/11/2017 4:47:02 PM • Bissell Carpet... • Answered on Oct 11, 2017
Need instruction manual for bissell 1640-4
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Bissell model by clicking the link below. Bissell 1640 5 Owner Manual You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/3/2017 2:42:29 PM • Bissell Carpet... • Answered on Oct 03, 2017
Why doesnt bissell carpet cleaner brush turn properly
Hello, this is Ava with Think Crucial. There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance. First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing. While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all. You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
8/27/2017 2:31:51 PM • Bissell Carpet... • Answered on Aug 27, 2017
My roller brush on my bissell vacuum doesnt work. the belt is good, why is it not working
Hello, this is Ava with Think Crucial. If your roller brush is not moving there could be several problems Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for troubleshooting solutions. Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction. You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/2/2016 10:07:38 PM • Bissell Carpet... • Answered on Nov 02, 2016
Location of serial no
Your User's Guide provides pictures and directions for that.
1/31/2016 10:01:50 PM • Bissell Carpet... • Answered on Jan 31, 2016
Why is the solution coming out of both lower sides of my Bissell carpet cleaner
First try cleaning the filters. One under the water tank cap (looks like a screen) remove it, clean and replace it. The other is a Flow Indicator Filter = unscrew the Flow Indicator remove the rotor and pull out the filter. Clean it and reinstall in reverse order. If that doesn't work the call the Consumer Care at 1-800-237-7691, Hope that helped.
1/30/2016 3:32:22 AM • Bissell Carpet... • Answered on Jan 30, 2016
Need the two clamps that hold the lower tank on tight. Model 1695
I didn't say this: You can use zip ties, Just make sure everything lays flat against the unit. Bissell Consumer Care number is 1-800-237-7691 and they may be able to give info on a dealer that could provide you with the proper clamps. Good Luck.
1/28/2016 8:16:19 PM • Bissell Carpet... • Answered on Jan 28, 2016
Why can't I use the attachments to clean my couch?
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
1/28/2016 7:29:30 PM • Bissell Carpet... • Answered on Jan 28, 2016
Lost paper work not sure if I register product
Call Consumer Care - 1-800-237-7691
1/28/2016 12:04:29 AM • Bissell Carpet... • Answered on Jan 28, 2016
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
455 questions posted
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
sprayer stop working
  • Vacuums
