is your vcr hooked up to your t.v. or through your cable or satelite box? if to t.v.,hook up through your cable or satelite receiver and this should solve your problem.... and should you need help with connecting cables to a receiver i can help you with that as well... i hope this was helpful...
JustAnswerhttps://www.justanswer.com > TV Problems
Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ...
1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sansui have specials name for it. They are always at the rear in the Connections Panel or close by.
ANT 75/RF Connection Connect to the antenna/cable TV output of your device or wall plate.
Forest Riverhttps://forestriverinc.com > Component-Manuals
PDF
Plug earphones into jack for private listening. Overrides speakers. USB Input. This input is for service personnel only. COAXIAL Output. Connect to your SPDIF ...
39 pages
Sansuihttps://sansuiworld.com > assets > qled-smart-tv
PDF
ANT: Connect the antenna to TV via coaxial cable on ANT jack of the back panel. • AV: The output AV terminal of DVD can be connected with the AV input port ...
30 pages
1. Check if the picture settings are set properly. Make sure the aspect ratio and resolution are correct for your TV.
2. Check your TV's display menu for any "Flip" or "Mirror" options and turn them off.
3. Check the connections from your TV to your cable box or HDMI device. Try unplugging them and plugging them back in to make sure they are secure.
4. Check the TV's user manual for any specific instructions on troubleshooting picture issues.
5. If none of these steps resolve the issue, contact your TV manufacturer for more help and advice.
To connect a VCR/DVD player to a Sansui flat screen TV, you will need to use the appropriate cables and connections. Here are the general steps you can follow:
Check your TV and VCR/DVD player for the available ports. The TV should have RCA composite video and audio inputs, and the VCR/DVD player should have RCA composite video and audio outputs, or HDMI port.
Using the appropriate cables, connect the RCA composite video and audio outputs from the VCR/DVD player to the corresponding RCA composite video and audio inputs on the TV. If your VCR/DVD player has HDMI port, use HDMI cable to connect the TV and the VCR/DVD player.
Turn on your TV and VCR/DVD player.
On your TV, press the "Input" or "Source" button to switch to the input where the RCA composite video and audio cables are connected or HDMI.
Using the remote of your TV, go to the menu and select the input where the VCR/DVD is connected.
If you don't see any picture, try adjusting the settings on your TV and VCR/DVD player.
Once you are able to see the picture on your TV, you should be able to use your VCR/DVD player as you normally would.
The codes for a universal remote to work with a Sansui television are:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
