20 Most Recent
Memorex MT201224 20" TV Questions & Answers
MY GRANDDAUGHTER TURNED ON/OFF OUR T.V REPEATEDLY
Try website like Remote.com to buy an original remote.Might still can used it with a remote.Tv might have shorted or dead,it power switch losely,tries press it turn power on now?Yes,tv worth repairing a swtich or PCB manual control board functions,just require replacing.
Brought this for son to play video games now i
may just need to have channels programmed into it. Go into menu on tv look for a heading of "channel" or "setup". You're looking to make sure that the tv is set for either cable or off air. chs.their should be a reference to "autoprogram" this will lock in the tv to whatever chs are available. goodluck
Greenish color whole screen
THERE IS APROBLEM IN VIDEO SECTION.OR CRT TUBE .REPLACED CRT BASE AND GREEN CATODE TRANSITOR OR WHOLE BASE IT WILL WORK OK
TV Audio
Try adjusting cables connecting dvd to tv. If this doesn't work try a different cable.
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
