20 Most Recent Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Questions & Answers
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Frigidaire 20.6... | Answered on Apr 08, 2017
Only should get voltage when it is actually calling for water. Voltage would be 120 volts.
Frigidaire 20.6... | Answered on Jun 06, 2015
It is usually right under the cover that houses the temperature controls
Frigidaire 20.6... | Answered on Feb 20, 2015
if the freg make more ice the problem is th thermostat but if the freg run without good cooling thats mean you micro-gas leakage
Frigidaire 20.6... | Answered on Feb 12, 2015
Hello friend, thank you for your post!
I understand that there is rust on the door of your Frigidaire refrigerator. Typically, rust is not covered under the warranty and in most cases the door will more than likely need replacing. If you would like to get a part number and availability I would recommend contacting the manufacturer directly. If you would like for me to locate that information for you could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your fresh food side. I look forward to assisting you. -Matt
Frigidaire 20.6... | Answered on Oct 20, 2014
Hey friend, thank you for your post!
On a top mount Frigidaire refrigerator the gasket is a magnetic strip which should be able to be easily removed. You would have to order a new gasket for your refrigerator which you should be able to reach out to the manufacture for part number and availability.
If you need any additional assistance with replacing the gasket I would recommend reaching out to a professional for proper replacement. Hopefully this information is helpful. -Matt
Frigidaire 20.6... | Answered on Oct 07, 2014
Thank you for your post, friend!
I understand that you are getting debris along with your ice that is coming from your Frigidaire refrigerator. I would be unable to provide you directions on how to clean out the piping for your refrigerator but if you have the model number I can check to see what kind of information is available regarding the filter. You can normally locate the serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Frigidaire 20.6... | Answered on Aug 13, 2014
Replace your ice maker. Your ice maker mold is flaking and collects into the ice. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Frigidaire 20.6... | Answered on Jul 24, 2014
I FOUND MY WIFE ONE AT LOWES. DONT RECALL THE PRICE BUT THEY HAD IT IN STOCK.HOPE YOU FIND ONE
Frigidaire 20.6... | Answered on Jul 08, 2014
Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
Frigidaire 20.6... | Answered on Jun 18, 2014
Good Morning Friend,
I understand that you want to know how to check the compressor on your Frigidaire refrigerator. I will be more than happy to assist you. In order to better assist, I kindly ask for the model number of your appliance. Typically, this number will be located inside the refrigerator area on the right or left wall. Looking forward to hearing from you.
-WP-
Frigidaire 20.6... | Answered on Jun 12, 2014
YOUR REF. MAY BE STUCK IN DEFROST. IN THE CEILING OF YOUR REF. THERE IS A CONTROL HOUSING. THERE IS AN ACCESS HOLE ABOUT 6 INCHES BACK MORE OR LESS IN THAT AREA. INSIDE THIS HOLE IS A ROUND GREY, BLACK OR RED PIECE THAT CAN BE TURNED IN ONE DIRECTION WITH A FLAT BLADE SCREW DRIVER. TURN IT. IF IT STARTS YOU WILL NEED A DEFROST TIMER. NEED MORE HELP JUST ASK.
http://www.searspartsdirect.com/partsdirect/index.action
Frigidaire 20.6... | Answered on Dec 03, 2013
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
215 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
no power inline valve ice maker
  • Refrigerators
