20 Most Recent
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Questions & Answers
I have a Hotpoint HSS25GFTA BB. The water is not
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
5/8/2017 12:31:19 AM •
Hotpoint...
Answered
on May 08, 2017
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more:
http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
3/24/2015 11:50:02 AM •
Hotpoint...
Answered
on Mar 24, 2015
How do you change part # wr55x10025
This is a thermistor. It depends where it is located how you would be changing it but the generic answer would be unplug the refrigerator. remove the old one leaving some of the leads from the old one before you cut the wires. so you have some wire to work with. Using small wire nuts or crimp connectors wire the new thermistor to the old leads from the old thermistor it is best to either fill the wire connectors or crimp connectores wirh silicone sealant or tape the connectors with electrical tape to prevent water from entering the connections. Put the thermistor into position and away you go.
4/13/2014 10:06:37 PM •
Hotpoint...
Answered
on Apr 13, 2014
Refrigerator not cooling, Freezer not freezing
no cooling at all on both sides? if thats the case do you have power to the unit ..lights on fans running then your compressor is not working check the starting components and hear if the compressor works also check the controls are they on or off? good luck..
12/8/2013 7:27:43 AM •
Hotpoint...
Answered
on Dec 08, 2013
Hotpoint refrigerator not defrosting
Is it not defrosting, or defrosting and re-freezing the meltwater as ice? Check drain clear. Further checks are 1) defrost timer 2) defrost heater 3) defrost klixon
8/8/2012 10:29:56 PM •
Hotpoint...
Answered
on Aug 08, 2012
