20 Most Recent Whirlpool ED5HHEXT Side by Side Refrigerator Questions & Answers
0answers
Refrigerator not freezing in the garage
You have to do these checks. Check for build up on the condenser coil behind the fridge. Check for MASS build up of frost in the freezer section. If you have that, unplug the unit for 3 days and let it defrost. You will have to check the parts on your evaporator to see if they're operating properly. Also make sure the compressor is even running. Try turning the fridge on. If you're not getting a hum out of the compressor but can hear it clicking, you more than likely have bad start components on the compressor. Also if the compressor isn't running, try tapping on the temp display/thermostat where you adjust the temperature if it starts, you probably have a bad thermostat. The fridge sounds like its been running for 2 days and it's dead hot in the unit, you have a system problem and should consider buying a new one.
5/19/2014 11:10:19 PM • Whirlpool... • Answered on May 19, 2014
Ice cube door between freezer and outside is not
Generally, ice cubes sometimes get stuck on the flexable cover and will not close properly if they get stuck between the flap and the chute. A hair dryer blasting on the flap will dislodge them and let the mechanism close properly
1/10/2011 8:35:20 PM • Whirlpool... • Answered on Jan 10, 2011
Installed a new icemaker approx 36 hours ago and
There is a wire lever that allows for the icemaker to be turned off. If it is in the up position the icemaker will not make ice.
1/2/2011 3:04:13 AM • Whirlpool... • Answered on Jan 02, 2011
HAVE A ED5FHEXT REFRIGERATOR MAKES A POPPING NOISE
there is a magnetic vinyl covered seal glued all around the door frame to seal the refridgerator from escaping cold. If this seal has come loose, it will adhear to the door frame a little after opening and then be pulled back and make a slapping sound. Check this seal to be sure it is not torn loose.
12/28/2010 5:05:38 PM • Whirlpool... • Answered on Dec 28, 2010
Refrigerator/freezer in garage not freezing
Most refrigerator Manufactures have tested these machines in hot and cold weather and weather will effect operation and electricity consuption.
As far as cold weather goes It would run much better in cold weather than hot. As far as it being in the garage : It will wear on it faster. The humidity is not good on them and they get more dirt through the system and will need its normal mantenance more often. not to mention bugs and rodents like to find a warm place to hid with fee dinking water and a refrigerator provides that for them.
1/9/2010 8:22:59 AM • Whirlpool... • Answered on Jan 09, 2010
Whirlpool wrv986fdem01 no lights
Check the control panel or display on the refrigerator for any error codes or indicators that might suggest a malfunction. Reset the control panel by unplugging the refrigerator for a few minutes and then plugging it back in.
4/3/2024 9:01:44 PM • Whirlpool... • Answered on Apr 03, 2024
Whirlpool refrigerator model WRB322DMBM0 1 with ice maker only. How do I find and change the ice maker filter
The Whirlpool WRB322DMBM01 refrigerator model typically does not have a dedicated water filter for the ice maker. Instead, it relies on an external water filtration system or an in-line water filter that may be installed in the water supply line connected to the refrigerator. Here's how you can check for and change the water filter for your ice maker: 1. **Locate the Water Supply Line**: Trace the water supply line that connects to the back of your refrigerator. The water supply line is usually a flexible plastic or metal tube that runs from the water source (such as a water pipe or faucet) to the refrigerator. 2. **Check for an In-Line Water Filter**: Look along the length of the water supply line for any inline water filters. These filters may be attached to the water line using compression fittings or push-to-connect fittings. They are typically cylindrical or rectangular in shape. 3. **Inspect the Filter**: If you find an in-line water filter, inspect it to determine its type and condition. Some filters have a label indicating the brand and model number, while others may have a date or indicator showing when it was last replaced. 4. **Replace the Filter (if Necessary)**: If the water filter is due for replacement or is visibly dirty or clogged, follow the manufacturer's instructions for replacing it. This typically involves turning off the water supply, disconnecting the filter from the water line, and installing a new filter in its place. 5. **Flush the System**: After installing the new filter, flush the water system to remove any air or debris. Run water through the dispenser or activate the ice maker to purge the system of any trapped air or loose particles. 6. **Monitor Performance**: Monitor the performance of your ice maker and water dispenser to ensure that the new filter is functioning correctly. It may take a few cycles for the water system to fully adjust to the new filter. If you cannot find an in-line water filter connected to your refrigerator's water supply line, it's possible that your refrigerator does not have a built-in water filtration system for the ice maker. In this case, you may need to consider installing an external water filtration system to improve the quality of your ice and water.
4/3/2024 12:33:05 AM • Whirlpool... • Answered on Apr 03, 2024
How to replace freezer light
Delete To replace the LED light in your Whirlpool WRSSDHW08 freezer, follow these steps:
  1. Unplug the refrigerator to ensure safety.
  2. Remove all the items from the freezer to give yourself more room to work.
  3. Locate the light cover inside the freezer. The LED light should be underneath this cover.
  4. Carefully pry the light cover off using a flat-head screwdriver or your fingers. Be gentle to avoid damaging the cover.
  5. Once the light cover is removed, you should see the LED light module. It may be held in place by clips or plugs.
  6. Disconnect the power supply to the LED light. This may involve twisting or pulling the plug from its socket.
  7. Remove the old LED light module from the freezer.
  8. Purchase a replacement LED light module from the Whirlpool website or an appliance parts store. Make sure to get the correct part number for your specific refrigerator model.
  9. Install the new LED light module by connecting it to the power supply and placing it back into its slot in the freezer.
  10. Replace the light cover by snapping it back into place.
  11. Plug the refrigerator back in and test the new LED light.
If you have any trouble replacing the LED light or if you are unsure about any steps, consult the user manual for your Whirlpool refrigerator or contact a professional appliance repair technician for assistance.
3/29/2024 9:30:21 PM • Whirlpool... • Answered on Mar 29, 2024
Why is my whirlpool refrigerator ice maker not working on whirlpool model # WRF535SMBM00. It seems we have no water filter
https://www.appliancepartspros.com/repair-help/whirlpool-refrigerator-wrf535smbm00-repair/wrf535smbm00-ice-maker-not-making-ice.html Whirlpool Refrigerator WRF535SMBM00 Ice maker not making ice Causes of a bad icemaker cycling thermostat can include electrical malfunctions, temperature sensor issues, or wear and tear. Symptoms of a bad icemaker cycling thermostat may include: Inconsistent ice production. The icemaker not cycling properly.
HOW-TO: Whirlpool Refrigerator WRF535SMBM00 Ice maker ...
There is no water filter.
Where is the filter for water for ice maker located on
JustAnswer https://www.justanswer.com > Appliance Repair Jul 23, 2018 - This particular model does not have a filter built into it so that is why you can't find one. If you wanted to add a filter, you can get an in- ...
2/23/2024 6:13:04 AM • Whirlpool... • Answered on Feb 23, 2024
2answers
Whirlpool refrigerator running continuously won't shut off but is not freezing stuff in fridge and freezer is working fine
Sounds like the evaporator fan is not running. Pull the inside of the freezer back off to expose the motor and replace it.
2/21/2024 6:59:51 PM • Whirlpool... • Answered on Feb 21, 2024
Whirlpool freezer defrosting too often causing food to thaw.
If it has a defrost timer, some are adjustable. If not just replace it. https://www.google.com/search?q=Whirlpool+freezer+defrosting+too+often ..
1/7/2024 7:49:35 PM • Whirlpool... • Answered on Jan 07, 2024
Whirlpool ET1MTKXKQ20. Temperature control.
Question edited for clarity, spelling of maker, toss in a load of CAPS. Question moved from Cars and Trucks. Yes they do. https://www.google.com/search?q=whirlpool+et1mtkxkq20 ..
1/1/2024 3:13:20 AM • Whirlpool... • Answered on Jan 01, 2024
Ice maker issues... Maytag Whirlpool French Door Icemaker in upper left. Help?
Question edited for clarity Zeros (0) and ohs (o) aren't interchangeable in serial numbers :>D If icemakers are going wrong it is best just to replace the complete icemaker unit. They work in a very hostile environment or cold, wet, electricity and limescale and bio-slime. Some commercial icemakers I have witnessed in catering facilities would have you never taking ice in a bar or restaurant again! https://www.google.com/search?q=Whirlpool+MFI26665XEW3+parts ..
10/17/2023 6:22:18 PM • Whirlpool... • Answered on Oct 17, 2023
Whirlpool ED5HHEXT Side by Side Refrigerator Logo
Popular Tags
13 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
refrigerator not freezing in garage
  • Refrigerators
