20 Most Recent
Electrolux ICON 30 in. Double Wall Oven Questions & Answers
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Glass
glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
Tried to clean single Electrolux wall oven. The
Seems
like you found out the hard way what I wrote about in this
tip...
Check it out it also contains some thing to try on how
to unlock that oven..
Self
Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I
never would have used the self cleaning option. Thanks for the info!!
" - amymrocks
The handle on the bottom
I suppose the handle you are talking about, is the long, wide one, used to pull that oven door open, right? I personally do not have any experience with this particular oven-- However:
These handles are usually held on by a long screw at each end.
So-- when you look at the handle-- do you see where the screws should attach at each end?
And do you see matching holes thru the door-- where the handle was once attached?
Now: Where are the screws?
We know they were there at one time, right?
So-- can you open the door, and can you locate where the screws are now?
Once you locate the screws, can you hold the handle, and re- screw the screws ito the threads in the handle? You have the necessary tools? -- Screw driver and flash light?
When you examine things closely-- get back with us, and we can help you to your next step.
Mack B
