20 Most Recent Roland V Drums Td12Sx Td12Kx Complete Kit W High-Hat And Twi Questions & Answers
Do you have an owner's manual......first thing to try would be a factory reset...sometimes this will un-scramble the operating system and set it back to when it left the factory....contact Roland for an owner's manual if you don't have one....hopefully this helps..if not, then you will have to open it up.....
Roland Music | Answered on Oct 04, 2019
"It's dead, Jim."
Bones McCoy
Roland Music | Answered on Sep 30, 2019
The most likely problem would be wiring. By dropping it you loosened or disconnected a wire.
Roland Music | Answered on Sep 27, 2019
It's always possible the new battery had lost it's charge before it was installed. Check it with an ohm meter for it's voltage. Other than that, either the contacts in the battery holder may be in need of cleaning or the battery wasn't installed correctly.
did you check the fuses and if thats not it then the light may be burnt out.
there are spraycans of cleaner that u can buy to cure it. sounds like dirty pots like maybe your volume pot on your amp or the pots on the instruments your playing. get the cleaner ,spray in the pots and move them back and forth and thats it. my marshall amp was doing the same and that was my cure. i dont remember the name of it but phone long and mcquade or another store and ask. hope that helps ya.
Contact Roland..They have owners manuals on their site for download...
Roland Music | Answered on Sep 24, 2019
It's usually fine to leave solid state electronic equipment turned on. A small amount of heat is produced when powered up and it will usually help to prevent condensation inside the case if that's a problem. It's not normally needed unless it's in a damp and/or cold environment. A dehumidifier is possibly a better solution if you have a lot of moisture.
Roland Music | Answered on Aug 18, 2019
Open up the Roland G-70 and check if all the connectors and flatcables are well seated. Check also if the power supply is working as supposed to.
Roland Music | Answered on Jul 26, 2019
rtm yet, read the manual on it for "troubleshooting" pages?
Roland Music | Answered on Jun 27, 2019
Roland V Drums Td12Sx Td12Kx Complete Kit W High-Hat And Twi Logo
1 questions posted
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
td 12 v drum kit am only getting sound
  • Music
