20 Most Recent
Samsung X640 Pink Color Cellular Mobile Phone Questions & Answers
Samsung Sgh-X640 phone freezed
hi it will be helpful for me to guide you the exact place if you had specified the country from where you brought the mobile and the provider to which your mobile is locked .you can get the codes from here
onlinegsmunlock here they ask the imei number of the mobile and finally they will provide you the unlock codes as soon as possible.
Downloading photos from mobile phone
You can do this by connecting the Samsung usb cable (which came with the phone) to your pc.It will self install the device onto your pc - you then open My Computer and should see your Samsung device.Open the folder of your phone to locate the photos, then drag-drop to your pc.
Can i unlock my new phone for free? cheers Gail
Welcome to FixYa
Dear User,
FREE UNLOCK code can only waste your Valuable Time/Sometimes it[FREE UNLOCK code] may Create Damage to your Phone.....DO NOT TRY ERROR CODE MANY TIMES
To unlock a phone you will first need an unlock code Click here .You need to Know IMEI of your Phone and Enter it when trying to find an unlock code[Select your Model as in Left side/Click on Picture of Model you have and Follow Steps]..
Hope you got it-Dont for get to Rate ME....Thanks for Contacting FixYa
Pink samsung tocco lite unlock code
You take a risk unlocking your phone if you are unsure what you are doing. You could well brick it. I personally wouldnt risk it. There are planty of places around that unlock on the spot.
Phone freeze unlock code
Aug 04, 2009- here you go this should work took me a bit to find
0.for most samsung phones hope it helps
1. remove your simcard
2. type *2767*3855# ALL DATA WILL BE LOST.
If the phone is locked with firmware then the code wont work.
LOcked PUK
well if u want it unlockedno other way to do it but to send it in to your local samsung dealer or drop in if one is close enough it will cost you around 45$ 1300 362 603 is the numb shop around stores ive heard of other stores being able to do it unfortunatly i cannot find the info on the net as the phone lock is case sensitive of each seperate phone if some how u find a workaround please repost ty
