20 Most Recent Sony DAV-IS10 System Questions & Answers
2answers
I have Sony DAV IS10. Can I upgrade the s/w so
No you cannot upgrade the system to play Dvix .
Thank You
1/3/2020 3:21:14 AM • Sony DAV-IS10... • Answered on Jan 03, 2020
2answers
Sony Dav-is10 cannot play new divx films,is there an upgrade to
no, you need to get diffrent films.
1/3/2020 3:20:37 AM • Sony DAV-IS10... • Answered on Jan 03, 2020
0answers
0answers
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
3/12/2015 2:11:55 AM • Sony DAV-IS10... • Answered on Mar 12, 2015
0answers
2answers
DAV-IS10 Speaker Blown
OK, Subwoofer model number is SA-WSIS10and you need middle speaker mounted on top under following part number..
1-826-658-11 LOUDSPEAKER (12 cm) (MIDDLE)
Available in Part Store.
12/31/2011 3:59:08 PM • Sony DAV-IS10... • Answered on Dec 31, 2011
Hi all, I hope someone out there can help me.
It's unclear where the sound is emanating or where it is lost in this scenario or even the type of connection you're using to carry it.
It almost sounds like you're using the TV for sound or it's in the audio path. The sound from any high end source should be processed by the SONY DAV as close to its original device as possible and not unnecessarily patched through the TV.
The TV only NEEDS Video. High-end Audio is wasted on it.
The symptom sounds suspiciously like a loss of data from the source to the Sony DAV.
Please clarify or establish that this does or does not happen without using the remote. Sometimes remote commands are heeded by unintended devices. Try to Pause/Play sequence using front panel buttons on the unidentified Samsung BluRay to eliminate that possibility.
http://www.retrevo.com/support/Sony-DAV-IS10-Home-Theater-Systems-manual/id/2771ag604/t/2/
Observe the indicators on the Sony for any clues when the problem occurs.
9/24/2011 1:18:29 PM • Sony DAV-IS10... • Answered on Sep 24, 2011
0answers
The speaker output has suddenly
check the back to see if any wires were pulled out/ loose by cats/ dogs/ kids or plants.
7/16/2011 1:41:52 AM • Sony DAV-IS10... • Answered on Jul 16, 2011
It does not switch on
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
2/23/2011 11:10:46 PM • Sony DAV-IS10... • Answered on Feb 23, 2011
Hello i have a sony
hi,
Any one of the output amplifier IC( integrated circuit) of ur sony have some problem. sony has an output protection circuit to protect ur speakers when the output ic become faulty. it will come to normal operation only after replacing the faulty component. normally sony uses SMD (surfase ***** dvices) ic.for replacing the same u need SMD rework station. better u consult the manufacturer
ok
12/30/2010 3:39:02 AM • Sony DAV-IS10... • Answered on Dec 30, 2010
3answers
Hello I have a Sony
yes, there has been hacks to make players multi-region. For your player, using a Logitech Harmony remote control may work. You can check the following link for reference: http://tinyurl.com/2df8xl3
9/28/2010 8:43:17 PM • Sony DAV-IS10... • Answered on Sep 28, 2010
Receiver error message reads: PUSH POWER
Hi, follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on your A/V receiver display..
Check the speaker wires and speakers for proper connection.
Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level, it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
Disable the surround sound option if both the A and B speakers are being used simultaneously.
Ensure the top of the receiver has proper ventilation to keep it from overheating.
If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Take care
6/11/2010 9:32:34 PM • Sony DAV-IS10... • Answered on Jun 11, 2010
Sony DAV-IS10 System Logo
67 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
dav is10 speaker blown
  • Audio Players & Recorders
