20 Most Recent
Sansui HDLCD-1900 19 in. LCD Television Questions & Answers
Hdlcd19wb series a -
How do
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
8/2/2018 5:29:05 PM •
Sansui...
Answered
on Aug 02, 2018
Wont come on
Some of the capacitors on the main board have burned
6/1/2014 7:11:23 PM •
Sansui...
Answered
on Jun 01, 2014
Sansui hdlcd 185W
I purchased one last night and I don't have any problems with it. It turns on and off normally. When starting this TV the first time setup it prompts to leave it in store mode (probably for store display purposes) or choose home mode, then it goes to search channels from your cable or air tv.It sounds like you will need to return it. Walmart should have more TVs like this on stock. They didn't sell well on the Black Friday.
11/28/2011 6:32:47 AM •
Sansui...
Answered
on Nov 28, 2011
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
6/11/2011 5:16:50 AM •
Sansui...
Answered
on Jun 11, 2011
Need Help how to setup
In order to set up HD you need either an HD antenna, or a digital cable/satellite box. If you have cable or satellite you have to make sure you have HD service through your provider. If you do just hook up your box to your T.V. using either HDMI or component (blue, green, red). Then you'll have to look through your channels to find out where your HD channels are.
5/5/2011 6:31:30 PM •
Sansui...
Answered
on May 05, 2011
I have a vga cable
you may need to change the resolution of the desktop it may not be correct for the input that the tv needs. also look for any buttons on the laptop that will switch the video over to the VGA output. i suggest tryin around 600X800 and see if it will show up. good luck
1/11/2011 2:33:29 PM •
Sansui...
Answered
on Jan 11, 2011
I bought an HP-desktop from a friend of mine, i
On current Sansui lcd and led tv's you must change your PC's refresh rate to 60hz to match the tv's refresh rate. How you do this will depend on what PC you have as well as what operating system. I hope this helps you.
Bobya.
8/27/2010 12:07:00 AM •
Sansui...
Answered
on Aug 27, 2010
