20 Most Recent Sony Bravia KDL-26S3000 Television Questions & Answers
Check the remote control for its infrared emission. Check it with fresh batteries. If remote control is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Sony Bravia... | Answered on Aug 04, 2016
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony Bravia... | Answered on Dec 09, 2014
Please see the troubleshooting chart, BU1 board part # A-1268-869-A, cost approx $230.7685cfa.jpg
Sony Bravia... | Answered on Jul 02, 2013
Long and short of it....you have to go through the process with the cable box.
Sony Bravia... | Answered on Sep 21, 2012
Download the user manual to your TV from internet. It will have all the details. Click here to downlaod the manual.
Sony Bravia... | Answered on Apr 19, 2012
Hello
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hoping this will help in solving the problem, take care...
Sony Bravia... | Answered on Jul 03, 2011
You will need to take covers off and physically check all cables and connectors see if any were dislodged. Pay attention to the ones that go to the lcd panel itself
Sony Bravia... | Answered on Jan 07, 2010
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Sony Bravia... | Answered on Oct 09, 2009
Hi Sherry, you can test your remote control to see if all the keys work correctly
Take your cell phone, put in camera mode and point the emitting LED of the remote control towards the camera,
press the keys, one at a time and see if the emitting LED is illuminated, if so, try the volume up key, if the light does not turn on, you could carefully disassemble the remote control and clean the contacts and the keyboard internally rubber,
Do not use alcohol to clean
the rubber keyboard, you can clean it with warm water and detergent then let it dry very well,
the contact plate, you can use a cloth with some liquid to clean the glass,
the idea is to remove the rubber residue on the contacts
then arm again and test, but you have results consult a specialized technical service
I hope you find the suggestion useful
Greetings Franco Dosil
Hola Sherry, puedes probar tu control remoto para saber si todas la teclas funcionan correctamente
Toma tu celular, pon en modo camara y apunta el Led emisor del control remoto hacia la camara,
presiona las teclas, una por vez y fijate si se ilumina el Led emisor, si es asi, prueba la tecla de subir el volumen, si no se prende la luz, podrias desarmar con cuidado el control remoto y limpiar internamente los contacto y el teclado de goma,
No Uses Alcohol para limpiar
el teclado de goma, lo puedes limpiar con agua tibia y detergente luego dejalo secar muy bien,
la placa de los contactos, puedes usar un pa?o con un poco de liquido para limpiar los vidrios,
la idea es sacar el residuo de goma que hay sobre los contactos
luego arma nuevamente y prueba, sino tienes resultados consulta a un servicio tecnico especializado
Espero te resulte util la sugerencia
Saludos Franco Dosil
Sony BRAVIA... | Answered on Sep 15, 2019
hello Dear
this is panel problem please replace panel
Thanks
M Nasir
Sony BRAVIA... | Answered on Apr 14, 2019
Sony Bravia KDL-26S3000 Television Logo
23 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
peform factory reset
  • Televison & Video
