20 Most Recent Vizio VX37L Television Questions & Answers
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Vizio VX37L... | Answered on Dec 18, 2018
Not to be a smart alek but buy a new tv
Vizio VX37L... | Answered on Jan 04, 2018
The problem is the main digital board. It does not have a reset button.
Vizio VX37L... | Answered on Nov 01, 2017
Did you hear any pops before the screen went black?
You've tried completely discharging it? Disconnect everything off the TV, all cables and power.
Press and hold the power button on the TV for at least 20 seconds.
Let it sit, and in about an hour, plug just the power in (directly to the wall) and see if it comes on. There should be an indicator light, is it white or orange now? Was it a different color before?
Odds are it's a board, be it the main or a video, don't know for sure. If you can take the back of the TV off and see if there are any evident signs of damage, blown or swollen capacitors, burnt traces or resistors/diodes, etc.
Vizio VX37L... | Answered on Oct 25, 2017
Your cable signals are probably encoded so that you have to use their cable box for reception. Renders your tv tuner useless used for OTA.
Vizio VX37L... | Answered on Aug 28, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Vizio VX37L... | Answered on Aug 08, 2017
I had the same problem with my 42" vizio. Was working fine for about a year and a half, then a month after all stations went digital, I couldn't see any digital channels and it wouldn't scan for digital signals
This is a strange go around, but it worked for me. . Tried unplugging, pushing power button for two minutes... did everything the forums suggest, with no resolve. But, here's what DID work for me. Trust me, it sounds strange, but it continues to work (and, yes... it's not a permanent fix... the channels still go out once in a while, but I can always get them back now)
Use your Vizio remote control. Turn your TV on. Press the "input" button until you get to "RGB", which is what you would connect a computer to. Make sure no computer is connected, or it's at least off if it is connected. When you get to RGB, you'll see a message that says "No Signal". After about 5 seconds, the TV will enter a sleep mode and seem as if it has turned off (orange Vizio logo). Once it completes it's little sleep cycle and "clicks" off, wait a few seconds and hit the input button again. It'll go to the next menu item. Keep clicking input until you're back on "TV", and VUALA! The channels are back!
I accidentally figured this out when trying to troubleshoot, but I'm glad I did. Didn't want to dishout $250 to get it fixed. Let us know if it works for you too!
Vizio VX37L... | Answered on Jul 26, 2016
Good common sense idea and I will remember it.
Vizio VX37L... | Answered on Nov 30, 2015
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Vizio VX37L... | Answered on Sep 06, 2015
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Vizio VX37L... | Answered on Aug 24, 2015
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Vizio VX37L... | Answered on Feb 23, 2015
Sounds like tuner fault. Contact any service technician. Electro help
Vizio VX37L... | Answered on Dec 22, 2014
Displays blue screen and shut down; denotes no signal input to TV. Check all the signal inputs, Ariel, AV or so. If all are found OK, the tuner to this TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Vizio VX37L... | Answered on Jul 19, 2014
Sounds like main board has damaged due to lightning. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Vizio VX37L... | Answered on Jul 08, 2014
Vizio VX37L Television Logo
228 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio 37l suddenly stopped getting all
  • Televison & Video
