20 Most Recent Sony BRAVIA KDL-40W3000 40 in. LCD HDTV Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Sony BRAVIA... | Answered on Feb 24, 2014
it is most likely one or two of the CCFL lamps
http://ccflwarehouse.com/30.html
which causes inverter board to fail.
Service Manual can be downloaded here
http://www.tradebit.com/filedetail.php/91116647-sony-kdl-40w3000-service-manual-repair-guide
only with a fee.
Sony BRAVIA... | Answered on Apr 18, 2013
When it goes off, you should get some kind of blinking led. How many time does it blink befor it pauses and starts again?
Sony BRAVIA... | Answered on Mar 20, 2013
Over Voltage Protection . this is the cause for 3 blinks you see by its stanby/power LED.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Sony BRAVIA... | Answered on Oct 17, 2012
hi here is a link to the stand for your tv at sony parts store >
http://www.partstore.com/Part/Sony/Sony/KDL40W3000/Sony/Sony/A1257997A/New.aspx
please dont forget to rate me i need a few more for my badge thank you and if you need anymore help let me know..
Sony BRAVIA... | Answered on Dec 02, 2011
Do you have standby power indication at least?
Sony BRAVIA... | Answered on Sep 18, 2011
I WOULD CALL SONY AGAIN.
IF THE PROBLEM PERSIST; YOU HAVE A TV PROBLEM THAT NEEDS TO BE CORRECTED.
Sony BRAVIA... | Answered on Jun 07, 2011
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this will to fix the fault......
Sony BRAVIA... | Answered on May 29, 2011
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Sony BRAVIA... | Answered on May 01, 2011
The LCD screen cracked from the hit of the weapon.
Servicing will most likely be more than a new tv.
I would contact a local certified repair center to get an estimate on the repair of your tv.
Sony BRAVIA... | Answered on Mar 08, 2011
Have you got the right model number this is an LCD TV, not a back projection set which uses a projection system. There is no bulb to take out on this model number.
Sony BRAVIA... | Answered on Feb 07, 2011
5 blinks means failed T-con AKA LCD controller board. It is the most in-expensive board in the tv and should cost you around 40$ for a replacement. It is also very easy to replace. Let me know if you want to fix it yourself so that I can give you appropriate instructions.
Sony BRAVIA... | Answered on Dec 10, 2010
Check that your 'input' button is on the right setting.
Sony BRAVIA... | Answered on Nov 05, 2010
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem. take care.......
Sony BRAVIA... | Answered on Oct 22, 2010
sony kdl-40w3000 does not turn on. Standby light keep blinking. What is the problem
Sony BRAVIA... | Answered on Aug 23, 2010
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Sony BRAVIA... | Answered on Feb 16, 2010
Usually Sony LCD TV has control buttons on top or at lower side of TV.
Let me know your TV model number to find out exact location of buttons.
Thanks.
Sony BRAVIA... | Answered on Oct 18, 2009
Sony BRAVIA KDL-40W3000 40 in. LCD HDTV Logo
51 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
3 flashing red lights when try power up
  • Televison & Video
