20 Most Recent
ViewSonic N2635w 26 in. LCD Television Questions & Answers
Input menu will not disappear
- This happens because a part in your remote is holding the input button down find what is and find a way for it to stop doing that.
N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
I need to get a
Tries websites like Ebay.com,Amazon.com to buy a used or new tv base stand.
Viewsonic n3625w turns on but has no signal and can't change input
If you are able to chaneg it from the buttons on it that means theres something wrong with the remote , you can test your remote control by pointing to a digital camera and press the buttons on it while you look at it from digital cameras display , hope that helps
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
I want to remove the text that appears on screen
U have the tv original remote wright?U are receiving and getting a Antena tv signal from free AIR DTV broadcasting channels?Yes,search ur tv remote for a button that said CC pushes that button a couple times make sure all functions like CC1,2,3.. to all off.If remote have no CC button,go into the tv menu look for Closed Captioning and Text like 1,2,3.. turn it all to off.The tv program Closed Captioning text on the screen will disapear.If ur are using Cable,Telicom,or satalite pay signals used their remotes.
