20 Most Recent
Philips DCP855/37 Portable DVD Player Questions & Answers
I have some movies (format *.avi) that I cannot
Hello Aristica,
There is No software download for the DVD plaer itself. Where you are going wrong is the Format ie avi that DVD player does not support it. You can Google free software to download which will allow you to convert you AVI file to something that the Dvd player will play:
DVD Video • VCD • SVCD • DVD-R • DVD-RW • DVD+R • DVD+RW • CD (Audio) • CD-R • CD-RW • Picture CD • Divx
so If you type in Google free Avi converter Then this will list several. You really want one that will convert to DIVX or VOB those will definately play on your DVD player.
I hope this has help you out. I tryed not to go into too much detail.
Cheers
Little Dish Fitter
6/23/2020 9:33:25 AM •
Philips...
Answered
on Jun 23, 2020
Gatorade on the dvd player .......
Yep get a bag big enough to hold the device & put it in dry uncooked rice, BUT please firstly cover any cable ports on the device with small clear tape to prevent any blockages to the earphone/cable ports, the rice will absorb the fluid from the device drying it out but you will have to leave it there for a few days to be sure it's fully dry, I have had this work on phones, tablets & laptops. Hope this helps ????
12/30/2017 9:50:57 PM •
Philips...
Answered
on Dec 30, 2017
I bought a philips PD7000B/12
Yes you can change the region code but it will have to be refered to the phillips service center in the states for a proper decoding to be done for you.
Have a wonderful trip back.
Hope this solution has been helpful?
6/20/2011 3:21:44 PM •
Philips...
Answered
on Jun 20, 2011
Can I buy a battery
Tries websites like Amazon.com,Ebay.com,Partsotore.com to buy a new battery or a compatible one.
5/27/2011 12:27:51 PM •
Philips...
Answered
on May 27, 2011
What kind of format should I use for sd card to
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
8/27/2010 3:02:24 AM •
Philips...
Answered
on Aug 27, 2010
Canyou help? My portable Philips
Hi,the problem is from the lens of the DVD player,it's either dirty or weak,however,this lens can be cleaned with the use of damped cotton wool and spirit or alcohol.
Thanks and take care
5/12/2010 9:05:35 PM •
Philips...
Answered
on May 12, 2010
Where can i find an ac/dc adapter for my philips
You are going to have to find out, the Ratings of that supply, you need to know what Voltage and current are supplied FROM it. Any AC/DC adapter, with the right, Current, Voltage and End Plug, will work. Often it can be found on the actual unit, itself. Or in the manual, under POWER: Now once you know this you can get a suitable one, the thing to watch though, is the Plug End, they are all different and critical. Now at places like Radio Shack, and the like, often you can buy after market adapters that are Voltage adjustable, PLUS they have a special "End" on them, that will mate with a number of differing "Ends" one of which, will no doubt fit the unit, as all regular ones are included and then some. Then there is eBay.
3/24/2010 7:52:04 AM •
Philips...
Answered
on Mar 24, 2010
DVD's will not fully load. I suspect that laser
I quite agree with you. But to be very sure, play also with Video CD and Audio CD plates respectively. These two show play properly.
Once a DVD player lens is getting weak, it would start selecting DVD plates, but would play Video CD and Audio CD well. And if the lens gets weaker, it might not play Video CD's properly.
You could use a cotton board to clean the lens of the DVD player, and see if it would improve while loading DVD plates.
Take care.
12/23/2009 2:37:04 PM •
Philips...
Answered
on Dec 23, 2009
Phillips dvp1013
Hello Canada416,
Check the following link to the
regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
1/20/2009 7:19:12 PM •
Philips...
Answered
on Jan 20, 2009
