20 Most Recent
Curtis DVD1045 DVD Player Questions & Answers
Universal remote code
For philips universa; remotes, the four digit codes are 0594, 0494, or 0091. You might also try coby dvd codes too.
While attempting to eject the
Well first of all you can try to reset your player to factory default settings, please follow the below steps -
With the remote control, press "SETUP" and you should see a menu box with the following tabs:
1- General Settings
2- Playback Settings
3- Record Settings
4- Language Settings
5- Channel Scan
6- Clock Settings
Choose the General settings and then go to "Restore Factory Settings"
1. In the General Settings menu, use the button to select
the Restore Factory Settings item and press the SELECT button. The OSD will display as follows.
2. Use the or button to select OK .
3. Press the SELECT button to restore all default settings.
Hope it helps......
Good Luck!!
Thanks
